Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 09-19-2004, 03:13 PM
spender spender is offline
Send a message via Yahoo to spender
serpentine belt tension (w/o tensioner pulley)
My 1987 GMC p/u/ w/454 has a serpentine belt with no tensioner pulley, of course. How tight should it be? I know that it should be tighter than v-belts, but how much play should I leave? 1/2 to 1 inch on v-belts, MUCH less on serpentine? THANKS- Spender (John)
Old 09-19-2004, 04:10 PM
mprtech mprtech is offline
Re: serpentine belt tension (w/o tensioner pulley)
The way Honda taught was, after adjusting you should be able to twist the belt 90 degrees at its longest section. if you cant loosen if it twists too far tighten.
