Old 02-26-2004, 02:31 PM
twizller twizller is offline
CD Changer not working :(
My 2002 grand prix se never came with a cd changer so i went on ebay and i purchased a cd changer that works with all gm models with the pre-trunk harness (which i didnt have). I went to buy the harness (#12344015) and installed and plugged everything in. Now when i try to play the cd, it says E33 on the radio (its the cassette radio without the cd player). I checked the wiring and everything seems to be fine.
Anyone know what is wrong with it and how to fix it?
Old 02-26-2004, 10:10 PM
dopey273 dopey273 is offline
first things first. Does your radio have changer controls? does it have a cd button on it. Even though they say the changer will work with "all" gm radio's doesn't mean it does. I would check the model # on your radio and your changer and go to a dealership to find out if they're compatable. Secondly, how do you know that the changer worked before you got it. You're just relying on somebody else's word.If possible, I would try you're changer in somebody elses gm vehicle that has either changer controls or a factory changer already installed, and see if it works. If you stilll get an error , chances are the changer's bad.
Old 02-27-2004, 08:09 AM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
Re: CD Changer not working :(
I go with dopey here. E33 means a tape or CD loading problem. The issue here is if the radio knows how to talk to the changer. Installing a phone line between a German and Spanish does not mean they can talk at all. Check the radio model to see if it supports a Changer
Old 02-27-2004, 09:21 AM
MethodMan420's Avatar
MethodMan420 MethodMan420 is offline
http://www.automotiveforums.com/vbul...d.php?t=190569
This may help you out a bit
Old 02-27-2004, 03:46 PM
I hve checked if the radio is compatible with a cd changer and it is. I asked on clubgp and they said it is, and it also has the input for the wiring harness (#12344015). I talked to the ebay seller and he said he will offer a full refund, as i think it is the cd changer. And also, none of my friends have a GM vehicle with the stock radio in it
Thanks for the help
02' Cd in-dash changer not working appel301 LS | MKZ 24 01-25-2016 02:26 PM
2000 GMC Jimmy 6 disk changer not working. cosmonaut Jimmy 2 02-17-2009 04:19 PM
CD changer not working jeffromax Mark VIII 3 06-19-2005 12:10 PM
Cd changer not working Jeffdz Grand Cherokee | Grand Cherokee SRT8 0 05-26-2005 02:49 PM
CD Changer not working on all disks houg Grand Cherokee | Grand Cherokee SRT8 2 07-11-2004 02:35 PM
