Old 02-24-2004, 05:19 PM
daniellebrian7's Avatar
daniellebrian7 daniellebrian7 is offline
Ground Wire Systim
DOES ANYONE KNOW ABOUT HYPER GROUND OR ANY OF THESE OTHER GROUND WIRE SYSTEMS ...THEY CLAIM THAT THEY GIVE YOU +5 HP+4-5 TOQUE I TALKED TO A MECH...AND A ELECTICIAN AND THEY BOTH SAY WITH A GOOD GOUND IT'S POSSABLE DOES ANYONE HAVE OR KNOW ABOUT THIS SHIT PLEASE RESPOND
Old 02-24-2004, 05:21 PM
Re: Ground Wire Systim
Plus Also Suposed To Help Throttle Response And Deliver A Smother Idle
Old 02-24-2004, 05:45 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
If your car has shitty ground, it will help... but likely not.
LOSE THE CAPS PLEASE
Old 02-24-2004, 05:49 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
First the 5 hp -- possible but probally like 2-3 hp
And do these work --- HELL YEA
Try it, it will work, and it will help the idle a lot from what i have heard.
You can make your own, just goto home depot and pick up some 4 gauge wire, and some connectors. And make your own.
But I would like to know (if anyone here does) what is the best way to hook them up (ie.. battery ground...to ... alternator ground... to ... ) I know they should return to where there started (i think) like make a full circle.
BTW, i know there are a lot of people on 2gnt that have done this, and they have LOVED it.
For Sale 98 Eclipse GS, 5 spd
Old 02-24-2004, 06:18 PM
whos got the rescipe for this like the way to route them .....i can get the 4 gauge ire and connecters?
Old 02-24-2004, 08:07 PM
afterhrsplayer's Avatar
afterhrsplayer afterhrsplayer is offline
Send a message via AIM to afterhrsplayer Send a message via MSN to afterhrsplayer Send a message via Yahoo to afterhrsplayer
This is where I found out how to make my own kit and ground it.
Ground Kit
Marquis
1993 Mirage
mirage performance
Old 02-24-2004, 08:27 PM
ashah000's Avatar
^^^ thank u
Next question: Are the alternator, and starter ground points the same on the gst and gs.
Old 02-24-2004, 08:31 PM
thanks afterhrsplayer did it make a difference?....hey ashah00 we got it .......i knew someone had to have it !
Old 02-24-2004, 08:35 PM
ashah000's Avatar
O yea and i have seen people go crazy and make it 1 gauge wire, that probally adds 20 lbs to the car. I think i may use 2 gauge for the alt ground and starter ground. (maybe not, im thinking about it)
Old 02-24-2004, 08:38 PM
yea i think i'm just goin to use the 4 gauge fuck it i hope this shit works ill do it this weekend ......
Old 02-24-2004, 09:31 PM
Well, on my car, it made my throttle response a little better and my lights brighter. But on my friends 91 GSX, he said that it made a big difference. He's also running a sound system in his car and the headlights don't dim when the bass hits like they use to. Glad that I could be of some help.
Marquis
1993 Mirage
mirage performance
Old 02-24-2004, 09:40 PM
amdsoldier amdsoldier is offline
You guys have a rough figure for how much money a 15ft 4 gauge cable costs?
I wonder if this would help me out with my alternator noise, hmmm...
Thanks for the link afterhrsplayer.
Old 02-24-2004, 09:49 PM
kjewer1 kjewer1 is offline
AF - Advisor
There are a few reasons this could help. I think the biggest would be that the spark plugs ground to the head, then the block. So if the motor isnt grounded well, you wont get as much spark current as you could. That would explain the couple extra HP, and the increase in throttle response.
Since a turbo car has a lot more trouble with the ignition system giving a good spark (plug gaps, wire quality, plug material, etc), you could stand to gain more. I may test this theory some day. I've been thinking about making my own ground straps and seeing if it helps the occassional misfires I get at high boost...
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 02-24-2004, 11:48 PM
JoeWagon's Avatar
Banned
Speaking of spark, I either had spark plug blow-by, or bad plugs because I would get misfires under boost and load. It isn't happening since I replaced them today, but if it does.. it might be the plug wire arcing to the head (not that great)
Old 02-25-2004, 07:03 AM
i got that msd ign.and it seems to work fine mitsubishi are known for that everyone i talked to said that it's happin to theres and the coil is only $80
REM wire touched my ground wire.. how can i fix the issue? alexdeer18 SC/SL/SW 3 07-14-2011 02:41 AM
How to ground wires CaboWabo Engineering/ Technical 9 07-17-2003 12:19 PM
R-1 Sports Grounding Wires jrgcivic '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 5 01-05-2003 05:29 PM
Ground Wires jrgcivic Car Audio 7 11-27-2002 03:46 PM
Help with a loose ground wire ned946 Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 9 12-05-2001 06:11 PM
