Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 09-12-2010, 04:03 PM
alexdeer18 alexdeer18 is offline
REM wire touched my ground wire.. how can i fix the issue?
recently i installed my sub system along with my amp.. i ran all my wire etc everything was working.. except i had hooked up my amp REM wire straight to my battery so that it was constantly on.. anyways when i was reconnecting the wire to turn on my amp it touched a little piece of copper from my ground wire, my radio doesnt turn on now, now do i know if my amp is even working.. anyone know what happens if you touch the REM with the ground wire? i mean i checked all my fuses nothing has any sign of blowing out, but still my radio won't turn on and without my radio on my amp won't turn on. plz help.. thx.
Old 09-12-2010, 10:56 PM
Cat Fuzz Cat Fuzz is offline
Re: REM wire touched my ground wire.. how can i fix the issue?
Seems like this is more a question for a car audio forum and not a Saturn specific issue.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
Old 09-13-2010, 12:25 AM
Ruley73's Avatar
Ruley73 Ruley73 is offline
This doesn't add up. If you wired the REM wire straight from the battery, the amp will turn on and stay on regardless of whether or not the radio is turned on.
If the REM wire didn't have a fuse installed in it and you just briefly touched it to the ground wire, it should just make a spark. However, if the radio is aftermarket (not factory) and connected to the amp with RCA patch cords, it may have blown the fuse for the radio or the CHIME fuse on certain Saturns since the RCA patch cords are also connected to ground internally at the amp and the radio. There is a slim chance it may have fried the radio too.
Make sure to check the fuse behind the radio (if it is an aftermarket radio), amp main power fuse, fuse on amp if equipped, REM wire fuse if installed, and the CHIME fuse in the I/P fuse block if it is a 1991-1999 Saturn S-Series too.
My rides:
2007 Chevy Equinox LT FWD
2018 Chrysler Pacifica Touring L
"If women don't find you handsome, they should at least find you handy!"
- Steve Smith (Red)
Old 07-14-2011, 02:41 AM
rosalez899 rosalez899 is offline
same thing happened to me, did you figure out what was wrong?
