Old 12-09-2002, 02:57 AM
jrgcivic jrgcivic is offline
Question R-1 Sports Grounding Wires
Does anyone have a step by step instructions on this product, or a similar one??? These grounding wires are supposed to increse hp by 3-5
and it should give you a bit more torque on the low end, and basically make the electrical system run more efficently. So if anyone knows how to install of where to installs these wires it would be much appreciated.
Old 12-09-2002, 03:20 PM
Tofuboy's Avatar
Tofuboy Tofuboy is offline
What electrical part is this ground wires for? I pretty much 100% sure that it will not even give you any HP increase at all by changing the ground wires unless you have an intermittent problem in the circuit.
The only electrical part that controls your car's performance is the computer (unless it's a carburetor). The ECU circuit in your car is very complex, a slight change of resistant will cause your ECU to operate differently so I highly recommend you not to fool around with the circuit unless you know the what you are doing and the consequences.
The ground wires in your factor car should flow normally at it's best operation, it will not make a difference if you only change the ground side of the circuit due to the HOT side wire gauge remain the same (it also depends on your resistant [load]). Anyway, I am just curious on where did you hear that it will increase your HP?
Power is nothing without control
The fastest driver is the one with skills
95 Civic EX
83 Toyota Starlet
07 Ducati Monster S4RS
Old 01-05-2003, 05:36 AM
q2ar13 q2ar13 is offline
Send a message via AIM to q2ar13
That reply was so bullshit.
Sorry to burst your bubble. But everyone who reads this that has a subscription to Import Tuner will back me up on this. They Dyno'd Similar ground wires on a Honda S2000 and got a top gain of 2.1 hp @6500 RPM, A Mazda RX-7 TT with a max gain of 15.3 @ 6500 RPM, and on a Nissan Maxima that got 11.6 hp gain @ 4500 RPM. So in fact despite all the bs you just got new ground wires do really increase hp. The websites listed for the ground wires installed are www.sunautomobile.com & www.xs-engineering.com
I had my 95 se for a mere five days and some ass hole without insurance already hit my front end. what luck. I'll have it back soon enough w/ a R33 front bumber hood graced by the beauty of carbon fiber.
Old 01-05-2003, 12:21 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
but it will give little to no power on a civic engine....i mean they are testing high hp engines with this product, in the ad they test a gsr and the gain is like 5. something hp im sure it would be a very tiny or no increase in hp on a low hp engine, it would provide a stronger ground tho....
2002 Acura TL Type S
1991 Honda Crx Si
Old 01-05-2003, 04:44 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
I was interested in trying them, so i will wait for someone to post how they work out...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 01-05-2003, 05:29 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
i read that article in import tuner too. i know that it will give you an increase in hp but i couldnt say how much it will give. but i do know that changing the ground wire will increase hp
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
