Old 12-15-2002, 10:41 PM
CaboWabo CaboWabo is offline
How to ground wires
Can someone tell me how to ground wires and what does it means? Other then that can someone tell me how to make my In Dash motorized LCD screen work when im driving? i got the clarion 925 and the lcd screen wont play anything unless teh E park is on.... someone told me i have to ground teh e brake wires in order for the screen to play while im driving... any help would be nice thankz
Old 12-15-2002, 10:47 PM
kris's Avatar
kris kris is offline
Off playing with fire.
To ground a wire, you just need to secure it to a good point in your car. Like the chassis, etc. What do you drive?
Old 12-16-2002, 12:26 PM
94 integra gsr
Old 12-20-2002, 11:43 AM
xxswtguy01xx xxswtguy01xx is offline
Lightbulb
if u had someone else install your screen like best buy or any store they will always disable the screen while u r driving because any active screen in the drivers view while the car is in motion is illegal. so if you know anything about radios take urs out and find the wire that goes to the ebrake find out exactly what having it up does for the screen and replicate that without using the ebrake in someother form.
Old 03-14-2003, 11:16 PM
teck teck is offline
Send a message via AIM to teck
to make it easier for you just get the e brake wire and put it together with your stereos gorund wire and bam thats it. it worked for me
check out my ride at:
http://www.cardomain.com/id/civs2000
Axis MOD 7's 18" - S2000 tailight conversion - Antenna, trunk & moldings shaved - APR mirriors - molded black widow 2 rear - Tokico Gas Shocks - Skunk 2 Coilovers - ALPINE CDA-9855 - iPod Adapter - Deck - Pioneer Digital EQ Hifonics - 1000w Alpine-600W Subs-12" Kicker Comp VR - 2 7in. visor t.v's - 2 12 in. t.v. on my roof heh
Old 04-20-2003, 02:55 PM
CivicSkater CivicSkater is offline
Banned
Easy way to ground a wire....
Go to where the seatbelt actually bolts into the chassis of the car. There should be a big bolt. Take the bolt off. Then get a washer. Put the wire that u are grounding in between the chassis and the washer(make sure that it is touching metal. Then, put it all back together. The seats belts are a good place to ground wires, especially the back ones.
Old 05-28-2003, 12:32 AM
BullShifter's Avatar
try to ground to bare metal instead of painted. sometimes this cant be avoided
Old 06-18-2003, 06:47 PM
Banned
Well, if it is painted, and like i said, if you do it on the seatbelts, you could always just grab a knife and scratch away the paint till you can see bare metal.
Old 06-26-2003, 07:46 PM
darkaccord darkaccord is offline
Send a message via AIM to darkaccord
"Grounding" just means you attach a wire to allow the electrons to escape the device. Basically you have to attach a wire to a really big piece of metal (e.g the chasis).
Old 07-17-2003, 12:19 PM
sp3cial_bl3nd's Avatar
sp3cial_bl3nd sp3cial_bl3nd is offline
Send a message via AIM to sp3cial_bl3nd
you can also just tap into another ground wire....
