Old 11-25-2002, 12:29 PM
jrgcivic jrgcivic is offline
Question Ground Wires
I was just wondering if anyone has heard anything about R-1 Ground Wires. It is supposed to collect all the groungs and ground them directly to the negative terminal of the battery. Is it a good idea or not???
Old 11-25-2002, 06:30 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
dumb idea .......... and here's why. NOTHING will provide a better, low resistance path back to the battery than the car's chassis.
Old 11-26-2002, 10:14 PM
dslkicksass dslkicksass is offline
Send a message via AIM to dslkicksass
Hes right. Pick a unpainted part of the chassis and just use that
Old 11-27-2002, 02:22 AM
ground wires
so what were the wires intended for then? Which parts? Will it be a big difference anyway if it is grounded to the body or straight to the negative terminal???
Old 11-27-2002, 11:20 AM
wagsaccordsir's Avatar
wagsaccordsir wagsaccordsir is offline
Re: Ground Wires
Ground Wires are good. They are actually proven to add 2-5hp on most applications. And yes they are basically just replacements for your older stock wires. They are more conductive and have less resistance, therefor providing a good solid ground, to engine and chassis....
MY ACCORD ON KENWOOD'S PHOTO GALLERY
MY ACCORD ON CARDOMAIN
"CHEAP THRILLS"
I DON'T CARE HOW MANY SKY DIVES YOU'VE GOT. UNTIL YOU'VE STEPPED OUT INTO COMPLETE DARKNESS AT 850' WEARING 95LBS. OF EQUIPMENT AND 68LBS. OF PARACHUTE. YOU JUST HAVEN'T LIVED.
ARMY AIRBORNE!!!
Old 11-27-2002, 01:17 PM
Lightbulb ground wires
nice car wagsaccordsir. SO which parts or where so I re-ground. Do you have those wires on your accord??? The wires came with seven wires and one block that is supposed to gather all the different wires and route them to the negative terminal. If you know what parts it is meant for, It would be much appreciated if you help me out. I say its worth a try.
Old 11-27-2002, 02:01 PM
I don't have them "YET", that is my next upgrade. As for exactly what wire goes where; I'm not sure. I'm suprised that the instructions don't tell you specifically. I can say that you either would wing it and match the lengths of the wires and swap em one at a time. (Be sure to disconnect your battery first. ) I do know that the negative terminal goes to your starter as well as your alternator, the engine block and usually on or around the valve cover, I think there is one on the backside of the block as well, not for sure though. Then of course to your chassis, making sure to also connect the engine to the chassis. I have seen people even run extra wire to each of their spark plug wells, (where they actually attach it to I'm not for sure). Well thats all I can come up with, I hope it helps you out. If nothing else call the company you got them from and ask them the specific grounding points. Either that or be patient and someone who knows exactly where they go will post.. If I come across any specifics I will be sure to post for ya.. Peace and good luck.
"CHEAP THRILLS"
ARMY AIRBORNE!!!
Old 11-27-2002, 03:46 PM
Audio Guy
I was thinking this was a car stereo type product .......... if it's a performance product that is meant for underhood applications, then it might be worthwile. Especially if it upgrades the size of the ground wires.
REM wire touched my ground wire.. how can i fix the issue? alexdeer18 SC/SL/SW 3 07-14-2011 02:41 AM
How to ground wires CaboWabo Engineering/ Technical 9 07-17-2003 12:19 PM
R-1 Sports Grounding Wires jrgcivic '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 5 01-05-2003 05:29 PM
grounding wires? Darkwing Exterior | bodykits | Lighting 5 12-29-2002 05:10 PM
Help with a loose ground wire ned946 Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 9 12-05-2001 06:11 PM
