Old 02-20-2004, 08:17 AM
Shoemake Shoemake is offline
Question 93 Taurus Idle ramps-up and down
My 93 Taurus will idle high and low (sometimes dying in the process) when I start the car. Sometimes when I don't have my foot on the gas while driving, the engine will start do this see-saw again. I've tried changing the Throttle Position Sensor (TPS) with no luck in solving the problem.
Old 02-20-2004, 10:50 AM
medicTA medicTA is offline
Re: 93 Taurus Idle ramps-up and down
Sounds like the IAC needs replacing.
Join the BEST board around!
http://www.automotiveforums.com/vbul...errerid=145342
Old 02-26-2004, 09:45 AM
Spitzer Spitzer is offline
Send a message via AIM to Spitzer Send a message via MSN to Spitzer
Hey if it runs up when on but you are not giving it gas and only then. I would have to say check to make sure your upper intake manifold is seated properly. A leak could do it. I did some work on mine and put it back in place. A bold striped and the manifold did not seat properly. It only ranged between a 500 to 750rpm fall or gain.
Old 09-10-2004, 12:10 AM
KrspKrmMom KrspKrmMom is offline
Send a message via AIM to KrspKrmMom Send a message via Yahoo to KrspKrmMom
I was having the exact same problem with my 92. I had the IAC cleaned, but a week later it started idling stange again. I asked around, and it turned out to be the oil pan gasket was bad, causing the IAC to be clogged. After I had that done, it worked fine!
Old 09-10-2004, 12:37 AM
2001BlackSES 2001BlackSES is offline
Hey, what does IAC stand for? I think mine needs cleaned too. I'd clean it if I knew what it was. When I initially start my car for the day while it's cold it starts up no problem, but then kinda stumbles, then RPM increases just a little and then comes down and then it's fine after that. Maybe my IAC is clogging up. I don't know. I noticed when I got my car a month ago it had been overfilled by about a quart. I drained it to proper level, but maybe something happened while it was overfilled. I don't know. My pan gasket it fine, not leaking or anything, yet.
Old 02-07-2010, 04:18 PM
yungtek yungtek is offline
I have dealt with this problem on several occasions. I found the problem mostly exists in the EGR (exhaust gas recirculating) circuit, but on occasion will be a vacuum leak. There are 3 parts to the EGR: the solenoid, the sensor, and the valve. Start by replacing the valve, then the solenoid and finally the sensor.
Old 02-07-2010, 04:20 PM
By the way IAC stands for Idol Air Control. Typically not the problem.
Old 02-07-2010, 07:14 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Yungtek, please refrain from posting in outdated threads. Also, the EGR valve is rarely at fault, the DPFE sensor is the most common part to fail on these Fords. The EGR valve is also easily tested using a common vacuum pump.
-Rod
Old 05-29-2010, 03:29 PM
okhedher okhedher is offline
hi i get the same problem
Idle goes up and down when cold adryan79 5 Series 1 07-08-2009 12:57 AM
my 92 grand am idle goes up and down when idling but runs good when driving scarylarry Grand AM 3 02-13-2009 11:37 PM
05 integra idle goes up and down alot while warming up Bucky Goldstein Integra 3 09-24-2007 03:46 PM
E150 idle ramps up and down; dies when you hit the gas crcrowe1 E Series 0 10-04-2005 11:05 AM
99 cougar idle is up and down quickkick Engineering/ Technical 2 02-08-2005 07:28 PM
