Go Back   Automotive Forums Car Chat > Honda > Integra
Old 03-11-2007, 05:51 PM
Bucky Goldstein Bucky Goldstein is offline
05 integra idle goes up and down alot while warming up
and it takes forever to warm up
it's my kid's car and I'm trying to fix it for him
we just put a JDM B18 in it, but it did the same with the old motor
any ideas?
Thanks!
Old 03-13-2007, 11:38 AM
InJ3cted's Avatar
InJ3cted InJ3cted is offline
Send a message via AIM to InJ3cted
Re: 05 integra idle goes up and down alot while warming up
sounds like there could be a bubble in the coolant system. Clean the IACV with some brake cleaner. Also make sure you dont have any vacuum leaks that could cause the idle to surge. Also you could try tightening the FITV on the back of the intake mani.
Also about it not warming up quick, did you replace the thermostat? It could be stuck open. Just replace it, its only 10 bucks.
Black 1990 CRX Si FI d16a6 R.I.P
1995 DC Integra LS jdmb18b w/ ys1 trans SOLD
1990 EF civic Si sohc ninja project Traded
1992 EG vx hatch sohc turbo/gsr swapped SOLD
1992 DA9 obd1 love, non-vtec love project
Old 03-17-2007, 06:13 PM
iVteC_PoWeR iVteC_PoWeR is offline
Send a message via AIM to iVteC_PoWeR
same problem in my gsr...InJ3cted just named everything i could possibly think of
Old 09-24-2007, 03:46 PM
dj yoshi one dj yoshi one is offline
try this if you still have the problem of erratic idle let the car warm up then take of the intake. There are two ports in the throttle body. Block the lower port while the rpms are at about 3000 if there is vaccum its your fast idle thermo valve the dealer usually wont sell it separate from the throttle body. took off mine due to the same problem and found plastic piece fully unscrewed so tightened it up car runs great
