Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 02-18-2004, 12:28 AM
shyaztecguy shyaztecguy is offline
'90 t-bird shake(vibrates) when headlights come
I have a '90 t-bird and I have noticed that when I turn on the headlights or the rear defroster the car begins to shake a little. Before the the headlights or the rear defroster is on the car is smooth you cant feel any vibrations of the engine. But as soon as the headlights or rear refroster comes on the car shakes( vibrates). Anybody have or had this problem? Any info would be helpful thanks.
Old 02-18-2004, 07:10 AM
michelq michelq is offline
Re: '90 t-bird shake(vibrates) when headlights come
look to ground wires in trunk for fuel pump and rear lights
Old 02-18-2004, 10:04 PM
thunderbird muscle's Avatar
thunderbird muscle thunderbird muscle is offline
Check to see if your alternator is putting out enough to keep up with the extra strain of the power being pulled. The 3.8 I used to have did that with the headlights and it turned out The pulley was loose and with the extra strain of the lights it would vibrate. No biggie hope to have been some help!!!!!!
Old 02-19-2004, 12:50 AM
I checked the alternator by disconnecting the positive wire from the battery while it was running. From what I heard if the car turned off when the positive wire is disconnected then the alternator is not putting out enough. When I tried that my car kept running so I dont think that is the problem. The pulley might be, I will check that out. Thanks for the info.
Old 02-19-2004, 02:38 PM
THUNDERIN'bird THUNDERIN'bird is offline
Hardly any alternator will keep an engine running at idle....they don't put out enough amps.....You have to hold the throttle open a little to keep the RPM's up to check it like that...
BUTTERS: Well, uh, gee wiz, I'm not w-watching television, Dad, I'm just laying here jackinit.
BUTTERS' DAD: Jacking it? Jacking what?
BUTTERS: Well, my hot, spicy, b0ner, of course, Dad.
headlight comes on when blow horn amantalv CR-V 2 03-17-2009 11:17 PM
help - '97 Camry headlights coming on when car is off ancdmd Camry/Camry Hybrid/Vista 2 03-07-2006 02:56 PM
Headlight come on when door opened won't go off luke1975 Caravan | Voyager 3 09-21-2005 01:17 PM
97 Bird Dying When Coming To Stop 97T-Bird- Thunderbird 3 09-17-2005 10:45 PM
