Old 09-07-2005, 12:16 PM
luke1975 luke1975 is offline
Question Headlight come on when door opened won't go off
I know this may sounds crazy but on my 1996 Plymouth Voyager the headlight come on when the drivers door is opened. They remain on for 10 or 15 minutes. The switch inside will not effect the lights, only until the door is cosed for a period of time will the light go off. The chime inside rings as if you forgot to turn light off. After the van is running they still stay on. Ever heard of this? Help? Could it be some computer in van, or BCC?
Old 09-07-2005, 08:48 PM
vipergg vipergg is offline
Re: Headlight come on when door opened won't go off
The BCM controls most of this stuff. you might try pulling the IOD fuse under the hood on the power dist. center above the battery for about 20 seconds and reseat , these things get confused sometimes.
Old 09-07-2005, 09:14 PM
I will try this. Thanks
Will let you know the outcome.
______________________________
Tried it.
Did not reset any thing.
Any other ideas?
Old 09-21-2005, 01:17 PM
lezco266 lezco266 is offline
When outside door handle is used to open the door in an older van, it sets a timer that lit the dome ligt for several seconds to one minute.... not 15 minutes!!
