Go Back   Automotive Forums Car Chat > Honda > CR-V
Old 03-17-2009, 12:29 AM
amantalv amantalv is offline
headlight comes on when blow horn
Hello,
Have a coworker with a 2002 Honda CRV..interesting problem.
Just replaced left side headlight cause it was out. A couple of days later, he realizes the right one is out too. He is driving around, blows the horn for some reason and realizes that the headlight now comes on. It is intermittent. He said he has witnessed this on two occasions. Tonight he went out to grab something to eat, and he said all worked normally.
Any ideas?
Thanks!
2007 Ford Mustang GT: Modified
2007 Ford Edge SE
1971 Torino 500: WoRkEd
Old 03-17-2009, 09:57 AM
Copytech99 Copytech99 is offline
Re: headlight comes on when blow horn
Grounding issue I would guess. Possible loose connection.
Not sure of the exact circuit...But in most cases with a 2 filament single bulb system it will be supplied with voltage at the terminal common to both filaments and the grounding of one of the other 2 terminals will turn on the high or low beam filaments.
Old 03-17-2009, 11:17 PM
Thanks!
Yeah, I did mention a ground/circuit issue and that this will involve chasing down wiring.
2007 Ford Edge SE
