Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 09-17-2005, 01:38 PM
97T-Bird- 97T-Bird- is offline
Send a message via AIM to 97T-Bird-
97 Bird Dying When Coming To Stop
I have a 97 bird and it has been dying out a lot when i come to a stop and it basically turns off for a second while driving and kicks back on...the rpms just drop then it dies...my uncle is a mechanic and says it maybe the fuel pump because its not pushing at what it should be i think he said 29psi when it should be at 32 i believe...or he said the oxygen sensor...any help?
Old 09-17-2005, 06:07 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: 97 Bird Dying When Coming To Stop
My book says the fuel pressure is normally 40psi in a '97. OK, everyone say it with me- Check your codes. How's that, cd6!
Old 09-17-2005, 07:36 PM
Re: Re: 97 Bird Dying When Coming To Stop
Thanks man im having my uncle come look at it tommorrow...ya i knew that check codes was coming
Old 09-17-2005, 10:45 PM
coondawg6 coondawg6 is offline
yassir---- how sweet to repeat------1,2,3, CHECK THE CODES 1,2,3,CHECK THE CODES-----CANT FIX THE CAR TILL YOU KNOW WHAT TO FIX--------- so much for the cheering career i guess bird has the specs though if youve got 29psi replace pump and filter---second thought recheck fuelpressure and unplug regulator should see a rise in pressure to max pump is capable of-----AFTER YOU CHECK FOR CLUES BY PULLING CODES LOLOLOLOLOL
DONT EVER LEAVE WELL ENUFF ALONE , ITS BORING.
