Old 02-14-2004, 08:56 PM
eclipse2quick21 eclipse2quick21 is offline
Compression Ratios.....
ok i know this may be a noob question but when i read that the compression ratio for a motor is 10.6:1....what does each of the numbers stand for? all i know about this is that lower compression is better for boost....is 10.6:1 good for turbo?
Old 02-14-2004, 09:16 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: Compression Ratios.....
The first # is the chamber volume at BDC, and the 2nd # is the volume at TDC. So the high value the 1st # is the more compressed the air fuel mixture becomes and the higher the cylinder pressure and more complete burn= more hp
That is a simplified over view, to go into detail would be way too long for me to type.
And the ideal CR for boost is 8.5:1 for real big boost and around 9.0:1 -9.5:1 for smaller boost.
Old 02-14-2004, 09:20 PM
EG_Civic's Avatar
EG_Civic EG_Civic is offline
whtteg beat me to it. I'd go with 9.0:1 myself. The reasoning for lower compression is that a turbo is forcing more air into your cylinders and more air means more fuel, so theres more actual air/fuel mixture in your cylinder. Its taking up more space.
Old 02-15-2004, 12:23 AM
B1SiR6A's Avatar
B1SiR6A B1SiR6A is offline
So0o0o0o0o high compression pistons are basically made for people running all motor cars ?
Cuz I knew a guy who was sayin that he put in high compression pistons and was running something like 12 - 15 psi...
"Check that young man for nitrous"
12.428 @ 92.5 Mph
Before, Now
12.000 @ 94.1 Mph
On 1000ft Track
Currently 4th in BHRA All Motor Class...Soon to be 2nd (I hope)
...Theres gonna be alotta slow singin, an flower bringin if I hear my car alarm start ringin ...
Old 02-15-2004, 09:26 AM
maxspeedhonda's Avatar
maxspeedhonda maxspeedhonda is offline
Send a message via AIM to maxspeedhonda Send a message via Yahoo to maxspeedhonda
Re: Re: Compression Ratios.....
Yes and no. Typically all-motor cars will want high CR pistons 12+:1. It is very possible to run that level of boost with a very good tune and race gas. People lower their compression for turbo to allow a tuning margian or error. For example, say you have a high CR and boost combo and you tuned it when the temp was about 70 deg out, well summer rolls around and it becomes 90 deg. If you are still running the same tune, there are going to be big problems. For a daily driven car with a typical street tune, yes you would be better off with 9.0:1, a smaller turbo, and pump gas.
Old 02-15-2004, 10:47 AM
B1SiR6A's Avatar
Thanks alot for clearing that up for me(damn I luv this site)...I think the guy was a BS case though
12.428 @ 92.5 Mph
Before, Now
12.000 @ 94.1 Mph
On 1000ft Track
Old 02-15-2004, 10:54 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Here is a simple explanation a third grader could understand.
imagine you have 10.6 glass's of water(BDC), now compress them into one glass(TDC), that is what the numbers mean.
Old 02-15-2004, 04:44 PM
got v-tec?'s Avatar
got v-tec? got v-tec? is offline
first off i dont understand why turbo is good for ls/vtec cuz of high compression. and also what is the best compression for nitrous? out of these 3.
10.4:1(civic sir b16a)
10.2:1(del sol b16a3)
10.0:1(gsr b18c1)
civ eg hb/b18c1
PT61 .68ar p-trim
Full-race pro street manifold
Neptune EMS
412whp@10psi 11.62@118
633whp@28psi 10.45@135
Old 02-15-2004, 05:13 PM
All those are fine for nitrous and turbo.
LSvtec doesn't nescessarily have a high CR, you can build it how you like, just like any motor.
Old 02-15-2004, 05:55 PM
got v-tec?'s Avatar
ya true. but what engine would be better for n20? do you want a bigger number in the middle? like the b16a? or a small one?
civ eg hb/b18c1
PT61 .68ar p-trim
Neptune EMS
Old 02-15-2004, 10:43 PM
what is a good comp. ratio to run turbo and nitrous together?
Old 02-15-2004, 10:48 PM
Re: Re: Re: Compression Ratios.....
The number in the middle is part of the first number. Remeber the glasses of water, 10.5:1 would be ten and a half glasses.
Old 02-18-2004, 02:56 PM
93hybridaccord 93hybridaccord is offline
You can run any compression ratio you like. Like it was said, it's just safer to run lower compression. Top fuel cars run in the 20:1 ratio area and they are pushing more boost than any of us ever will. Basically, if you are running 10:1 cr and somone else is pushing 9:1 cr, it takes more boost for them to accomplish the same amount of hp you are making with less boost. None of what I just said makes any sense does it?
93 accord - jdm h22a
2003 srt-4 - daily driver
Old 02-18-2004, 03:13 PM
Sure, you can run whatever you like, but your motor may not like it
Old 02-18-2004, 05:00 PM
It's all about tuning.
compression ratios and method of compression SPOOK(I) Impreza/9-2x/Outback Sport 2 05-28-2013 06:26 PM
Compression Ratio = Gear Ratio?? The LH Engineering/ Technical 8 04-23-2006 10:10 AM
Compression Ratios....drift..your sarcasm welcome hehe VTEC_boi Engineering/ Technical 16 03-18-2004 06:30 PM
how to lower compression ratio? liquid8 Forced Induction 5 03-11-2002 04:59 PM
compression ratio b16b bomber '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 01-23-2002 12:47 AM
