Old 02-06-2004, 09:58 PM
ted_ex's Avatar
ted_ex ted_ex is offline
when is fuel cut?
At 15 psi WOT when is fuel cut?
Old 02-08-2004, 06:01 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: when is fuel cut?
Fuel cut happens when you hit a certain airflow. When you hit that airflow level depends on several things pertaining to your particular setup. Its not at a certain rpm, a certain psi, when the stock fuel system is maxed out, etc. Just at a predetermined airflow level... I'm not even sure what that airflow level is, or if it would mean anything to you (datalogger).
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
No start, has spark, has fuel, only when warm? anyone? ateball7 Achieva 0 02-14-2009 08:19 PM
Fuel Cut Off To Early. Cut Off At 6500rmp outsider6 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 7 08-08-2007 04:39 PM
91 Accord SE idles fine when cold cuts out when warm. HELP lowgeo Accord/TSX/Accord Hybrid 2 04-05-2006 06:56 PM
fuel cut or ignition cut on MR2 turbo???? TEAM KLR MR2/MR-S 9 01-28-2004 01:20 PM
Fuel cut off or not enuf fuel? quiXilver '88 - '91 Civic | CRX | Wagon | Shuttlee 5 05-18-2003 08:18 PM
