Old 07-31-2007, 09:33 AM
outsider6 outsider6 is offline
Fuel Cut Off To Early. Cut Off At 6500rmp
I SWAP A B16A1 IN TO MY 92 HATCH VX BODY. THE PROBLEM I AM HAVING IS THAT IT WONT GO PAST 6500RPM. IT IS REDLINEING AT 6500. V-TECH WORKS, I SWITCH THE FUEL PUMP, IM USEING AN 92 EX ENGINE HARNESS, USING A P28 ECU WITH A SKUNK2 CHIP(4800RMP TO 9000RPM) I'VE TRIED A P30 ALSO A P72 AND THE SAME THING HAPPENS. THANK YOU FOR READING. HELP IS NEEDED PLZ.
Old 08-01-2007, 02:16 AM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: Fuel Cut Off To Early. Cut Off At 6500rmp
Could be a bad distributer or weak fuel pump. I'd bag that chip though.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 08-02-2007, 09:08 AM
thats what i thought too. but i did switch the distibuter and switch the fuel pump to a integra fuel pump. the same thing happens. also the fuel cut off isnt at the same spot all the time. it changes from 6200rpm to 7000rpm. what chip should i use instead of the skunk2 chip then?? thank you
any other ideas why my fuel is cutting off like this??
Old 08-03-2007, 09:20 AM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
hmm.. did you get that chip off ebay? its probably not a true skunk2 chip unless you got it from an authorized skunk2 dealer. and when you did the swap, why didnt you put in the b16 ecu?
If you dont have the ECU, i would just chip it and run a b16 basemap from crome
Old 08-08-2007, 12:04 AM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
eh... nobody did it... so I have to... not that it has any relevance to the thread.. but it's *vtec* your engine is not a phone.
Old 08-08-2007, 01:16 PM
well, i just got done switching spark plugs and fuel injetors. same thing seems to be happening. but now the cut off seems to be a little higher now. its from 6500rpm to 7800rpm. it seems that i am buring rich. i rebuilt my b16 motor, i put in ctr pistons and rings, also clevit bearings and ported the head. do u guys think i need to break the motor in more. also with the ctr pistons, would u guys know what compression im sitting at? thanks..
Old 08-08-2007, 01:19 PM
compression, have no idea, but there is a thread on here somewhere that has compression ratings with each head/piston combination
you should be checking your basics, ignition tension (with a multimeter), fuel pressure, pump, filters, etc... get yourself a haynes manual for the car that the engine came from, and one for the car that you have... they'll help more than having nothing at all.
Old 08-08-2007, 04:39 PM
Kind of a Big Deal
you neve answered the question about the chip...
