Old 04-02-2006, 04:58 PM
lowgeo lowgeo is offline
Exclamation 91 Accord SE idles fine when cold cuts out when warm. HELP
It started doing this a few months ago so i parked it for the winter hoping it would fix itself haha. it seems to idle just fine when the motor is cold but when it starts to warm up it hesitates and loses power but it does not do it all the time it comes and goes almost like flipping a switch on and off. i replaced the speed sensor and the fuel filter within the last year. please contact me if you have more questions. thanx
Old 04-04-2006, 09:46 AM
vicchang vicchang is offline
Re: 91 Accord SE idles fine when cold cuts out when warm. HELP
It could be the EGR valve.
Old 04-05-2006, 06:56 PM
skybee skybee is offline
Afriend just brought the same car and its having the same problem too... but i mostly suspect it is ignition related.If you let the car idle till it warms up , it will start cutting out , but does not die. I suspect either the igniter or the coil in the distributor being faulty..
