Old 02-04-2004, 09:44 AM
perna00's Avatar
perna00 perna00 is offline
Send a message via AIM to perna00
anyone with oversized injectors
i have a 96 cav ls convert 2.4. i recently tried to use Venom oversized injectors and it cause my engine to do nothing but miss. i also had a few wiring problems with my car but they've been fixed since. i have headers, hi-flow cat, catback exhaust and cold air intake. does anyone have about the same setup that is using venom or any other brand larger injectors that are seccessful and if so does it make quite a difference? thanks
Old 02-04-2004, 02:20 PM
WhiteCavaliac WhiteCavaliac is offline
Send a message via AIM to WhiteCavaliac Send a message via Yahoo to WhiteCavaliac
Re: anyone with oversized injectors
You got to back them injestors up with a bigger fuel pump. Dont forget you running a 2.2l pump, but you know venom does sell high flow Z24 pumps.
Old 02-04-2004, 02:22 PM
Forgot that I need a 2.2l fuel pump! PM me if you want to sell the old pump.
Old 02-04-2004, 06:31 PM
perna00's Avatar
anyone using the injectors with the stock pump?
Old 02-05-2004, 09:08 AM
ScubaSteveo665 ScubaSteveo665 is offline
Send a message via AIM to ScubaSteveo665 Send a message via MSN to ScubaSteveo665
Exclamation Your Injectors
Dude all you gotta do is get a fuel pressure regulater. its a cheaper alternative to buyin a high flow fuel pump. you can turn it up almost all the way and that will stop ur sputter and miss. The only problem is it is hell on the fuel pump if your racing or running ur car hard. it will eventually burn ur pump up cause ur making it work 100% all the time. its up to you, my buddy did that and its worked for a year. its all about how u drive it.
Old 02-05-2004, 06:25 PM
perna00's Avatar
where can you find an adjustable fuel pressure regulator for a 96-2.4. i haven't had any luck yet or else i would have gotten it already.
Anyone removed the injector harness without removing intake? 95 year or higher searcherrr Windstar 2 07-09-2010 04:52 PM
Anyone cleaned fuel injector before? shab_xp Altima 0 04-29-2008 09:42 AM
Anyone Use an Apexi SAFC With Large Injectors (500cc or Higher), Please Reply!!! jeffseby N2O | Turbo | Superchargers 4 09-13-2004 11:56 PM
Anyone with an Automatic Turbo or anyone have any knowledge on the subject? SPEEDY Engineering/ Technical 8 04-14-2002 02:11 AM
Anyone with experience with Eurobuyers? nd89sc88 3 Series 0 01-09-2002 10:55 PM
