Old 02-04-2002, 11:10 PM
SPEEDY SPEEDY is offline
Anyone with an Automatic Turbo or anyone have any knowledge on the subject?
few questions...*** keep in mind this is only for daily driving and occasional racing***
I was thinking of getting the Greddy Turbo kit and keeping it at the preset boost level (5.5 psi) for my stock internals. Do you think it would be fine? Also how would it work with the autotranny? Would the tranny hold up? since your foot will always be on the gas while the ecu shifts gears for you..will it keep spooling up ? I thought about supercharging with the JRSC unit but read and heard stories about em so i changed my mind to the Greddy Turbo unit..Also what would be the "necessities" for the turbo kit? meaning if your money situation was tight and you only had enough money to afford the turbo kit and 2 other things that are essential for the set up..what would it be? i know i can go a little without the intercooler..i was thinking of getting turbo timer and fuel pressure regulator or fuel rail. Would Vtec be a big problem with the turbo? i heard it might cause some problems..I dont wanna swap out the engine or autotranny..reason being is i want to be different know what i saying ? i know im not going to beat any big v8's out there or anything i just want to give my car a little more kick and be able to beat or hang with GSR's..
00 Civic coupe..C-G-P
Greddy Turbo Kit
Apexi N1 Exhaust
Black Housed w/ ion Lense headlights
Carbon Fiber Euro Altezzas
Wings West Type W kit
Universal Commando
White 16" Motegi MR7's w/Toyos
Eibach Prokit w/ Tokico Blues
Old 02-04-2002, 11:38 PM
civicx_xracer's Avatar
civicx_xracer civicx_xracer is offline
Well I just wanted to give you my quick opinion on one of the things you asked about. You said you could only get a couple more things on top of the turbo...forget the turbo timer-just let your car cool down before you shut it off. Running a turbo on a vtec is not a problem. Running a turbo on an automatic shouldn't be a problem cuz I've seen turbo's on lots of autos(but I can't be 100% sure if it's ok) As far as what else to do...at least a fuel pressure regulator, prolly a fuel rail, boost gauge(unless it comes with the kit ) Do you have anything done to it now?
Old 02-04-2002, 11:59 PM
So far what i've done to my car is in my sig..performance wise..just intake header and exhaust...all stock internals..i've heard 5.5 psi is fine with stock internals..
Greddy Turbo Kit
Apexi N1 Exhaust
Universal Commando
Old 02-06-2002, 11:13 PM
mAtC's Avatar
mAtC mAtC is offline
Send a message via AIM to mAtC
Re: Anyone with an Automatic Turbo or anyone have any knowledge on the subject?
I would go with the fuel rail - personally
don't think so
------------------------------------> [email protected]
Check out my huge civic gallery at http://matc_civic.tripod.com
And hopefully, another one when I get more time.
PureHONDA.com vetern since January 2000
Old 02-07-2002, 01:08 AM
VTECseoul VTECseoul is offline
Send a message via AIM to VTECseoul
AUTOs & turbos work fine together; look at Grand Nationals & Syclone/Typhoons. you will have constant boost & no loss of power when shifting gears. you can power brake, when racing, & reach peak boost early in the RPMs.
if anything, getting a www.levelten.com tranny upgrade can help.
2000 Honda Accord LX Satin Silver Sedan
AEM ColdAirIntake
Neuspeed Sport Springs
Nitto 450 225/50
Prime Racing M8 17x7
S15 vs AE86 - 2006 HotWheels Touge
Old 02-08-2002, 08:10 PM
piscorpio piscorpio is offline
Send a message via AIM to piscorpio
Way back when, I emailed Jackson racing about using their supercharger with an auto tranny. They said it should hold up fine, but suggested getting a transmission cooler upgrade. I know it isnt a turbo, but it should not be all that different. Also, Ive always heard that a fuel rail is not so essential until you start getting into more serious modification. On the other hand, I rarely see any forced induction set up without a fuel pressure regulator. I know this is alot of second hand info, but I hope it helps.
Old 04-13-2002, 03:30 AM
A20A1's Avatar
A20A1 A20A1 is offline
Send a message via AIM to A20A1
Get a tranny cooler with a fan and fan shroud... don't rely on the radiators fan to cool the oil cooler and the trans fluid since the radiator fan isn't always on... unless you rig it to do so.
Keep the stock oil cooler hoses hooked up to the radiator base or where ever the stock cooler is.
B&M I found does a great job of dissapating heat quickly once the fan is turned on or when you are driving.
-MIKE
"THE REWARD IS IN THE JOURNEY..."
3geez member since: September 11, 2001
Cardomain
89 Accord
95 Corolla
Old 04-13-2002, 08:01 AM
kane2g kane2g is offline
Send a message via Yahoo to kane2g
you mean you dont have auto tranny cooler? OMFG, get the oil cooler for like 40 bucks form summit and some erls fittings and hook that sucker up. It took me like 45 mins to do it all.
The only thing that will kill your auto is neutral-drop or heat.
92 fastback 240sx AKA Ess1Tree Cuz its green, and hasn't moved in months.
Old 04-14-2002, 01:11 AM
iLLuCiv99's Avatar
iLLuCiv99 iLLuCiv99 is offline
Send a message via AIM to iLLuCiv99
Well a BOV still work good w/ auto/turbo? Does the throttle being wide open at all times, does that affect the BOV? Thanks for the info
J+L
Anyone with Grand Am GT and alero knowledge please read!!! Base-To-GT Alero Alero 21 09-26-2008 08:04 AM
Have any of the Formula 1 / Race car enthusiasts built any Revell F1 cars? wkma7six Car Modeling 12 10-02-2002 10:17 PM
anyone with LS/turbo? Craig The Unholy Forced Induction 3 01-01-2002 01:03 AM
