Old 06-19-2010, 11:28 AM
searcherrr searcherrr is offline
Send a message via AIM to searcherrr Send a message via MSN to searcherrr Send a message via Yahoo to searcherrr
Question Anyone removed the injector harness without removing intake? 95 year or higher
Anyone done this?
Its a huge job to remove the intake just to get at the fuel injector wiring harness. I'm particularly interested to know if anyone's done it for the 95 year, but I guess any year will do if you can describe what master TRICKS you used to do it.
Thanks!
1995 3.0L 3000GT NA FWD ATX - ProwlerGT on 3si.org
1995 3.8L Ford Windstar GL
"I drive the newest 1995 Ford Windstar anywhere..... when its not broken."
Old 06-22-2010, 02:33 PM
tums tums is offline
Re: Anyone removed the injector harness without removing intake? 95 year or higher
I am not shure what you mean - on my 96 the harness can be just pulled off, it is sitting with clamps on the railing on the backside use a mirror for a better sight.
Old 07-09-2010, 04:52 PM
Question Re: Anyone removed the injector harness without removing intake? 95 year or higher
On the 95 the intake manifold (upper) is just above the fuel injector wiring harness that goes to each injector (6 plugs + 1 that goes to the PCM). I cannot access the harness unless I remove the intake manifold which means a whole hell of a lot of extra work cause you can't get under the intake manifold with your hands. I was just wondering if anyone had done it with some special "reach in" tool that can go where hands can't.
