Old 01-22-2004, 08:52 PM
QuiksilverGT QuiksilverGT is offline
Question serious confusion!!!
I was told that you cannot put a GTP supercharger on a GT but you can get a dry shot NOS system and that is ok. somebody please explain it to me, I understand why i cant add the supercharger, but I dont understand why the NOS is ok.
Old 01-22-2004, 09:45 PM
jon@af's Avatar
jon@af jon@af is offline
The Media Guy
Send a message via AIM to jon@af
Re: serious confusion!!!
Well, you CAN put a GTP supercharger on a GT, but you'd have to change a lot of things like your PCM, intake, wiring and such, and there is a lower compression in the GTP, but it can be done. However, Im not sure about the nitrous question.
AF User Guidelines <----Click and read if you don't know these.
"Dream as if you'll live forever. Live as if you'll die today."
A Blog By Swigz
Cotidie damnatur qui semper timet; Aquila non captat muscas.
Old 01-22-2004, 10:13 PM
Ripn12s's Avatar
Ripn12s Ripn12s is offline
Send a message via AIM to Ripn12s
Both GTP's and GT's have been proven to respond to Nitrous very well, usually on stock blocks no higher then a 75 shot.
Adding the blower to the GT is alot of work. I think the only thing that the GTP(L67) and GT (L36) motors share is the bottem end and maybe the pistons. Intake manifolds are way different, cranks pulley, wire harness, pcm, throttle body, and I'm sure some other things would all have to be swaped in.
One of the chicago club members attempted this swap and became so frustrated that eventually he just swapped the entire motor.
I think either a motor/trans swap or a CSC blower are the best 2 options for the GT.
Old 01-23-2004, 12:57 AM
fast98gtp's Avatar
fast98gtp fast98gtp is offline
Send a message via AIM to fast98gtp
^^yeah i agree. i think even the pistons are different(from what iv read anyway). the gtp's are stronger so it can handle the boost...like the rest of the engine. i think it's pretty much only the block that's the same. if you're going to do one of the two, id say do the nitrous...far less expensive and a whole lot easier to install.
Old 01-23-2004, 10:40 AM
JJUBECK JJUBECK is offline
Yeah the gtp is built with beefer rings, rods, crank bearings, pcms, fuel injectors, wiring harness, throttle body, pulleys and so much more. I have a gt and have thought about this transfermation many times.
Old 01-23-2004, 06:58 PM
Ripn12s's Avatar
QuikSilver,
http://www.zzperformance.com/zzp/pro...gal_sc_kit.htm
Old 01-25-2004, 12:52 AM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
And also remember the fuel pumps. All that is related to the intake is different. You need more fuel to burn more air that is entering the plenum. So all the fuel delivery system is different even from the cams up. The timming if you check the options at http://www.zzperformance.com for cams swapping you'll find that the L67 cams have longer intake timming thant the L36 ones.
Serious Problems?Serious Problem? jessiebighamKC Grand Prix 24 03-06-2009 11:59 PM
Serious, Very Serious, Let's Talk About Rice Dyno247365 '96-'00 Civic 39 04-16-2006 05:25 PM
serious question for serious tuners sunsetsandturbos RX-7 14 04-20-2005 12:13 PM
seriously confused-set me straight hotgrlzracin Philosophizing 13 12-16-2004 01:32 PM
i seriously seriously need some help mein lancerevoV Lancer 1 12-08-2001 01:31 PM
