Old 01-22-2004, 07:34 AM
dr_latino999 dr_latino999 is offline
Send a message via AIM to dr_latino999 Send a message via Yahoo to dr_latino999
Ground Wire Spots
Ok, after some doing myself and what's not, I have changed the ground wire on the valve cover on the passenger side that connects to the body, but that is only one. Where are the other ones located?
Old 01-22-2004, 09:43 AM
Autocratic_1st_Gen's Avatar
Autocratic_1st_Gen Autocratic_1st_Gen is offline
Re: Ground Wire Spots
the other one connects from the battery, to the chassis, then to the transmission.
I would suggest adding one to the alternator and to the block.
-Dustin
i have a 91 Civic DX with 3x as much money in it as what i paid for it
i wish it was fast
here is my website
http://www.geocities.com/krustindumm/index.htm
Old 01-22-2004, 10:02 AM
Re: Re: Ground Wire Spots
So it would be
  • Battery --> Chassis
  • Transmission --> Chassis
  • Block --> Chassis
  • Alternator --> Chassis
Is this correct?
Old 01-22-2004, 10:16 PM
correct, everything goes to the chassis.
factory is:
Battery<---Chassis<---Transmission (one wire)
Chassis<---Valve cover
since everything flows towards the battery (shut up you double E's)
-Dustin
i wish it was fast
here is my website
REM wire touched my ground wire.. how can i fix the issue? alexdeer18 SC/SL/SW 3 07-14-2011 02:41 AM
How to ground wires CaboWabo Engineering/ Technical 9 07-17-2003 12:19 PM
R-1 Sports Grounding Wires jrgcivic '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 5 01-05-2003 05:29 PM
Ground Wires jrgcivic Car Audio 7 11-27-2002 03:46 PM
Help with a loose ground wire ned946 Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 9 12-05-2001 06:11 PM
