Old 01-20-2004, 09:58 PM
stangfreak7 stangfreak7 is offline
Send a message via AIM to stangfreak7
help with intake
hey i was wondering if the experts here could give me some advice and some insight on what i should do. i have a 94 mustang gt that is fairly stock aside from headers, gearing, cold sir, throttle bodies, etc... and i am looking at a trick flow track heat intake. i was wondering if that would help my car any and what i need to do to get its full potential out of it. also i was wondering if i would need to switch heads (which i plan to do, but probally not at the time of the intake) or anything else. i have an e303 cam that will go in at the same time and cobra rocker arms, along with new lifters. will i be able to get good preformance out of this intake with my car still half way stock, or should i look elsewhere. thanks for any help anyone is willing to give...
Old 01-20-2004, 10:17 PM
eillob's Avatar
eillob eillob is offline
I am no expert, Trick flow is a good intake, I run a ported GT40 intake myself.
Think of your engine as an hour glass, with the top being your intake the center being your heads and the bottom being your exhaust. You can put any kind of intake on this motor you want, you will not get full potential out of it until you put on better heads. Heads are the big restriction on a stock motor.
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator
(If it doesn't scare the Hell out of you it isn't fast enough)
Old 01-20-2004, 11:58 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Stock head intake ports and Trick Flow intake ports don't match up at all. Major airflow disruption also as said all over here try to stay away from the alphabet cams much better 1's available these days.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 01-21-2004, 03:40 AM
SpoolGT SpoolGT is offline
Perfect answers boyos... Get some heads before shelling out for an intake. Most intakes cost half about as much as heads do but wont give you any notice able power dif till you get some less restrictive heads.
Old 01-21-2004, 07:37 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: help with intake
Well, I really hope you weren't talking about putting in the cam when you do the intake? A cam would better off installed when you have the heads off for their swap.
As far as the track heat intake goes, might not be a good idea. You will more then likely lose some low end torque from it, and I wouldn't recommend it for a mainly street driven car that doesn't see much use of the top end.
GTStang, I didn't have a problem when I had my stock heads with the trick flow street heat intake.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 01-21-2004, 08:24 AM
MustangRoadRacer's Avatar
MustangRoadRacer MustangRoadRacer is offline
yes, track heat are for serious applications, 6000+RPM is where you see the real gain, which isn't seen to often on the street.
The Edelbrock performer Rpm or,Performer RPM2 would be my choice.
but the real answer is in the heads as previously posted.
on a stock engine, the key is to keep everything in moderation.
putting $1500 CNC ported big DART heads on a stock motor is a waste. Get some stock heads like Edelbrock performer, Trickflow Hi port, Gt 40, etc.
Mustangs are nice, but I'd rather have one of these...
Old 01-21-2004, 09:31 AM
well i can get a deal on some gt 40 heads and intake, how would that help my performance out in terms of hp. also, i was wondering what the differnece was between the gt 40 and the gt 40p, and which one would be better to run. Oh, and what cam should i run if i stay away from the alphabet cams??? how much lift etc...
Old 01-21-2004, 09:40 AM
gt40P is alluminum. Less weight, probably the same power.
with the ehads and intake you might get 40-50hp.
cam choice for a setup like this, go with crane or comp, and tell them your driving habits, mods, and temp/altitude of where you live, and they will pick the best cam for you.
Old 01-21-2004, 11:08 AM
HiFlow5 0's Avatar
Stanger
Re: Re: help with intake
GT40P heads are cast iron! Also refereed to as Explorer heads, cause they are found on the certain explorers. They are a better flowing head then stock, but cannot compare to a nice alum set. Typically P heads will cost about $500-$650, whereas a nice alum head will cost over a grand. P heads still lack flow on the exhaust side, just like the stock E7's.
GT40 heads are either cast iron or alum. I wouldn't even buy the iron one's, but the alum one's are a decent head, and are far better then the P and GT40 iron heads. Although GT40's are somewhat out dated compared to the huge after-market of alum heads now available, such as AFR's or Edelbrock.
Valve sizes are;
Stock E7's: I 1.78", E 1.45"
GT40P: I 1.84". E 1.46"
GT40 iron: I 1.84 E 1.54"
GT40 alum: I 1.94" E 1.60"
With a good set of heads and intake, you may see an increase of 40-60 hp, depending on combo. As for cam, Crane 2031 or the 2030 cam.
-2013 Ford Flex
-1999 Ford F150
Old 01-21-2004, 01:11 PM
HiFlow, what setup should i run then if i want the max. low end to mid performance from my car, with the crane cams u suggested. can u give me some names that seem to hold up well and out preform alot of competitors. i am looking for the most bang for the buck so to speak. something that gives some serious results but are still applicable for the street. what rocker arms, lifters do u reccomend also and anything u want to add. thanks for the help. im trying to figure all this out before spring so i can put my car up for several weeks and get it ready for the summer car shows, etc... and i want it to be layin down some respectable horses for them...
Old 01-21-2004, 02:22 PM
HiFlow5 0's Avatar
Stanger
Ok, if it were my car here's what I would do. This is considering that there's faily low mileage on the stock bottom that is in good shape.
Edelbrock Performer II intake
AFR 165 heads
1.6 rr's
New lifters and pushrod and ARP head bolts.
Crane 2030 cam (50 state legal)
75mm MAF meter
70mm TB
3 core radiator
190 LPH fuel pump
24 lb-hr injectors
adj FPR.
That's pretty much where I would start with the motor. All that will set you back roughly about $3,300-$3,500.
-2013 Ford Flex
-1999 Ford F150
Old 01-21-2004, 03:10 PM
what do u think about the edelbrock performer aluminum heads, i can get a good deal on them too. how would they work for my car...
Old 01-21-2004, 03:14 PM
and one more question, what is the difference between the cobra 1.7 rocker arms and a 1.6, etc...
Old 01-22-2004, 12:31 AM
GTStang's Avatar
Stang Guy
Difference betweem a 1.6 and a 1.7 is the ratio of the rocker. Simplest explianation is this a 1.7 will simulate having a higher lift cam than a 1.6. But this is not always a good thing.
Old 01-22-2004, 04:07 AM
my bad about the heads.
get the rockers that match up with your cam.
need help with intake air temp sensor mvb1212 Celica 2 05-12-2005 02:09 PM
Need help with Intake Manifold vacuum hoses xavierfg Engineering/ Technical 2 07-05-2003 10:24 PM
Need help with Intake Manifold vacuum hoses xavierfg '88 - '91 Civic | CRX | Wagon | Shuttlee 3 06-26-2003 09:42 PM
Help with intake swap 91civhatch '88 - '91 Civic | CRX | Wagon | Shuttlee 8 04-05-2003 03:27 PM
Need help with intake on 92 Civic LX sageuvagony '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 03-19-2003 10:58 PM
