Old 04-04-2003, 07:44 PM
91civhatch 91civhatch is offline
Help with intake swap
Hi guys im converting my dx 1.5 to mpfi and i was wondering if it would be a good idea to get the si engine harness???? if i did would everything bolt right up no stripping of wires???? please help someone was telling me i need to do so much shit like cam and $hit..... any help would be really appreciated thanks.....
Old 04-04-2003, 07:57 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
you dont need the cam to do the mpfi swap, but yes the wiring harness will help alot, make sure you get the injector resistor box too, its on the shock tower.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 04-04-2003, 08:04 PM
resistor box is on the way also but someone was telling me the sites on the boards for the swap are wrong
Old 04-04-2003, 08:07 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
try www.4thgenerationcivic.com
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 04-04-2003, 09:21 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
yeah i just did that swap, dpfi to mpfi, well i am not done yet just gotta do the ecu stuff. took me about 4 hours
Team Lonely Drivers
Old 04-04-2003, 10:17 PM
where did u get he info from civkiller?
Old 04-05-2003, 05:24 AM
i got it from the june 02 issue from scc, which is exactly with www.4thgenerationcivic.com has except it doesnt say that c2 goes to b12.
but when doing the swap, ive found that there were a few more mods needed than what said, well there were for me cause i didnt wanna hack up my stock harness. so if u dont wanna hack up your stock harness, you gotta
1. legthen the tps wires
2. legthen teh oil sensor back there, it has a cover on it, but theres 2 wires underneath it
3. then the exhaust mani o2 sensor is in the back of the engine, so u gotta run a wire from teh connector to the back of the engine.
4. then the green and yellow wire on the tranny connectors need to be lengtheh
5. the dx distributor plug doesnt match the si plug, so u either gotta get an si plug or just put a connector and just match up the wires without a plug.
thats all i can think of for now
Team Lonely Drivers
Old 04-05-2003, 11:14 AM
91civicDXdude's Avatar
You have to get a different distributor. the DX distributor desnt have a cylinder position censor OR a crank angle sensor if im not mistaken, since the DX injection just squirts gas into the common plenum and whatever valve is open gets gas whereas MPFI relies on crank position and cylinder positoin to determine which injector to fire and when...
Old 04-05-2003, 03:27 PM
yeah i know, im saying the the dx plug doesnt have the room for the 2 extra wires u gotta add, and the dx plug doesnt match up with the si dist. plug. so that why i was saying u either gotta get a si dist. plug or just match the wires up and put connectors on them.
i never mentioned the 2 extra wires cause thats already in the directions for the mpfi swap.
Team Lonely Drivers
help with intake stangfreak7 Mustang Talk 21 01-25-2004 11:10 PM
help with b16 swap need parts and help 92b16si Engineering/ Technical 1 12-08-2003 01:19 AM
Need help with Intake Manifold vacuum hoses xavierfg Engineering/ Technical 2 07-05-2003 10:24 PM
Need help with Intake Manifold vacuum hoses xavierfg '88 - '91 Civic | CRX | Wagon | Shuttlee 3 06-26-2003 09:42 PM
Need help with intake on 92 Civic LX sageuvagony '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 03-19-2003 10:58 PM
