Old 03-19-2003, 09:31 PM
sageuvagony's Avatar
sageuvagony sageuvagony is offline
Send a message via AIM to sageuvagony Send a message via Yahoo to sageuvagony
Unhappy Need help with intake on 92 Civic LX
I have bought an intake (short ram) a while ago now and I just realized that I had the blue tube installed wrong. there was a black hose coming out of the engine, so I plugged the blue tube into that and have been running it like that ever since and taped up the second hole in the intake. I just saw on a pic on a post here that a sensor or something gets plugged into there but I am wondering where that sensor is. Here is a pic. and also, there are like 2 metal hoses connected together. 1 was what the blue tube replaced. the second one I dont know what its doing.. it goes from the cam to the bottom of the engine.. the thing is that they are kinda stuck together so now that old hose is just there doing nothing.. is that normal? and installing these hoses and sensors wrong, could it impact my performance?
1997 Integra GSR and 1992 Civic LX
Old 03-19-2003, 10:58 PM
limitk7 limitk7 is offline
The black hose that you disconnected from the stock intake is a breather hose - it's welded to a coolant line. That's what's running from the cam to the bottom of the engine. It has nothing to do with your intake now that you've disconnected the breather hose. Your new breather hose is the blue hose you have connected. Is your intake a generic intake, or is it specifically made for your vehicle? I have an AEM CAI installed in my car, and the intake only has one opening for the breather hose to attach to. I'd say that your installation is correct - as long as you have the other hole plugged up firmly, you should be fine. But perhaps someone else should confirm (or deny) this.
need help with intake filters muugen00si JDM Motor & Parts info/chat 1 11-04-2008 12:06 PM
Need help with intake issue... Moze Silverado 10 03-04-2006 06:35 AM
need help with intake air temp sensor mvb1212 Celica 2 05-12-2005 02:09 PM
Need help with Intake Manifold vacuum hoses xavierfg Engineering/ Technical 2 07-05-2003 10:24 PM
Need help with Intake Manifold vacuum hoses xavierfg '88 - '91 Civic | CRX | Wagon | Shuttlee 3 06-26-2003 09:42 PM
