Old 01-05-2004, 10:21 PM
oldsaltdoggie's Avatar
oldsaltdoggie oldsaltdoggie is offline
Send a message via AIM to oldsaltdoggie
Cool Back in the Saddle Again !!!!!!
I'm new to this forum and glad to be back in a "stang" ( Its been 20 yrs at least, When I was in my late teens I had "67FB, 68 GT FB, 70 NB and a 72 NB".
I just bought a "94" V6 Auto "Blah" in the spring, $2000. seemed like a good deal! And yes I know these V6 ers SUCK!!! Head gaskets are going and blew the AOD in the last Nor'easter, Man this car sucks in the snow LOL. Any way my intentions where and now are to dump a V8 in it!! "Psss dont tell the wife" he he he I was thinking of a 347 and wanted to know if the AOD could be rebuilt to stand up to it or should I go with C4,C6 ? I also wanted to know what would be a good cam for this motor, I plan on driving it every day, "excecpt when the snow flys" . Also I may put a NOS system in the future
P.S. A lot of guys are telling me to go carb , and I'd like to keep it EFI Whats your take on this!!
Oldsaltdoggie
Me and My Stang 1994 Soon to be Back!!!
Old 01-05-2004, 10:27 PM
SIKCRX SIKCRX is offline
Re: Back in the Saddle Again !!!!!!
welcome back to the mustang world
Old 01-05-2004, 10:29 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
i can't offer you much advice in this area. a 347 would be cool, and you can probably rebuild that AOD for that much power (how much are we talking about here?) personally, i'm putting a 351W together, which will be bored and stroked to 408. and it's getting EFI, probably the CHP Super Spyder. i'm also putting a t56 behind it. i like EFI because of the fact that it tunes itself. that makes it worth all the extra work and such. and there really isn't too much more work anyway. cam doesn't matter that much as long as it breathes good for whatever heads you use. good luck tho, and we won't tell your wife =D
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 01-05-2004, 11:48 PM
parrish5o's Avatar
parrish5o parrish5o is offline
Whats up? Glad you could join us. The V8 is a must and it just gets better after that. Check out my setup, close to what you described.
CANFIELD STAGEII HEADS SCORPION 1.6 COMP CAM 555/570
GT40 INTAKE STAGEII LOWER 65MM TB PRO-M 75MM MAF
30LB INJECTORS 190LPH FUEL PUMP/ NOS INLINE PUMP
FMS ZT5 CENTERFORCE CLUTCH HURST SHIFTER
ALUM DRIVESHAFT 31SPLINE MOSER AXELS AUBURN DIFF
ALUM RADIATOR MSD 6AL MSD ADJUSTABLE TIMING RETARD
NOS STAGE II 150HP 497@5800 474@4300 11.3@118
Old 01-06-2004, 02:07 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Yea an AOD can definetly be built to handle that. The only thing is a well built AOD cost more than an equal C4 or C6. But the OD band does make for the better highway/gas mileage car.
Came selection will really depend on what heads, intake, CR etc.., you decide. Yea you can just get a general cam that works for what you doing. But being a lil more picky can pay off huge.
FI or Carb. Either is fine FI is more money to set-up and get to run properly but will in the end make more power. Carb set-up will be cheaper and can run decently easier and quicker but will never be as efficient
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 01-06-2004, 07:15 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Just remember that you are going to have to do a lot more work then just slap a motor in that car. Such as driveline, rearend, fuel system, computer, wiring harness, motor mounts, suspension, brakes etc. Going carb would be easier to set up then EFI, but I doubt you will pass any emissions like that. AOD's can be built to be pretty damn stout, so can't AOD-E's, which is in your car. If your looking to spend some cash on an automatic, look into Lentech or Artcar trannys. They are pretty much unbreakable.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 01-06-2004, 08:53 AM
MustangRoadRacer's Avatar
MustangRoadRacer MustangRoadRacer is offline
for the motor, check out badasscars.com
they built my killer 347, and even though they have more experience with carbs, did a great job on my efi setup.
coast high performance is supposed to be good too.
both can help with cam selection. unless you keep the nos to a low level (100hp or less) you will need to do some serious reworking of the fuel system and may need a new cam to get the most from the nos.
sounds like you have your work cut out for you!
have fun and rock on.
Mustangs are nice, but I'd rather have one of these...
Old 01-06-2004, 12:03 PM
GTStang's Avatar
Stang Guy
Don't ever buy a Nitrous cam for a street car. A nitrous cam that drops ET's on the 1/4 mile with nitrous is a dog when N/A. You'll be much happpier with a higher ET's but way more N/A performance.
Old 01-06-2004, 01:02 PM
trueness.
I have a track mentality that gets me in trouble sometimes.
Old 01-06-2004, 05:29 PM
parrish5o's Avatar
I can back this up, for the most part. I presently run a Comp nitrous cam. Naturally aspirated it is decent. Nothing great but it does perform well, I run consistant 12.4-12.5s. On the bottle it is the best I've found, so far. A Lunadi custom nitrous grind will soon replace it. But I do like this cam even thouth it's in my daily driver.
Old 01-11-2004, 07:00 PM
Re: Re: Back in the Saddle Again !!!!!!
I have a rearend and suspension and fuel system from the same guy I'm buying the motor from. I will need to find wiring harness and computer though!
Old 01-11-2004, 07:06 PM
HiFlow5 0's Avatar
Stanger
Re: Re: Re: Back in the Saddle Again !!!!!!
You should be able to find then anywhere. 50resto, Painless, Mustangs Unlimited, and many more.
-2013 Ford Flex
-1999 Ford F150
Old 01-12-2004, 09:06 PM
I should be getting started on my pony this weekend I'll take some pics and post them as I go!!
Old 01-17-2004, 04:30 PM
Pics Tommrow!!!!
Back in the Saddle!! 6.6403 @ 102.68 chevytrucks92 Non Specific 13 04-05-2006 09:28 PM
I'm back in the saddle again!! -The Stig- Street Racing 17 12-05-2004 05:53 PM
Bringing back the A23? Stodgy's at it again! Veyron Formula-One 1 07-18-2003 07:09 AM
