Old 12-28-2003, 03:56 PM
ripcurlguy ripcurlguy is offline
Can i run 4 ohm subs at 2 ohms?
I have two rockford HE and a 501s(125rms x 2 at 4ohms) amp for them. I'm not sure how to run them at 2 ohms or even if it is possible. If someone could help that would be great.
Old 12-28-2003, 04:09 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
you just hook the 2 speakers in parallel (+ to + and - to -)...... but be forewarned, when you bridge the amp, each side of the amp only "sees" 1/2 of the load. Rockford amps don't usually like 1 ohm stereo (2 ohm bridged) loads.
Old 12-28-2003, 09:45 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Can i run 4 ohm subs at 2 ohms?
you cannot run a single 4ohm sub at a single 2ohm load, so no. You could wire those 2 speakers together to get a SINGLE 2ohm load, but then you could only use one channel of the amp since it's not stable at 2ohm when bridged.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
can i run these @ 2 ohm? dragon370 Car Audio 4 03-29-2007 12:26 PM
Which is better 2 ohm or 4 ohm subs jackjordan86 Car Audio 4 07-06-2004 12:35 AM
4 ohm? 2 ohm? ViperJ Car Audio 5 04-13-2004 09:49 PM
Wiring a 2-ohm Sub Diesel2NR Car Audio 4 02-19-2004 05:49 AM
Forgot I had this 4 channel Pioneer Amp! What ohm sub would be best? Hybrid93Hatch Car Audio 2 08-11-2003 12:05 AM
