Old 07-03-2004, 10:30 PM
jackjordan86 jackjordan86 is offline
Which is better 2 ohm or 4 ohm subs
Im thinking about gettin a Kicker S12L5 and wanted to know which one is better the 2 ohm or the 4 ohm, or does it really matter. Im kinda new at all this stuff, and was just wonderin.
Old 07-03-2004, 10:53 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Re: Which is better 2 ohm or 4 ohm subs
there is no better, You just have to base it off the amp you are going to be using
www.cloudcity.deviantart.com
Old 07-04-2004, 12:42 AM
SickVette SickVette is offline
Send a message via AIM to SickVette Send a message via MSN to SickVette Send a message via Yahoo to SickVette
Jack...Haibane is correct. The reason the subs are available in different impedances is for different configurations. Lets say you have an amp that will do 1 ohm mono and you want to use 1 sub. Then a dual 2 ohm voice coil sub is what you want. If you want to use two subs then you will need 2 dual 4 ohm voice coil subs or 2 single 2 ohm voice coil subs. The impedance is so you can match your sub configuration with your amplifiers for the best possible results.
1999 Corvette coupe 600rwhp and way too much stuff to list everything here.
Audio Pioneer AVH P7500 DVD w/xm
2 PG Ti 600.2
1 PG TiDEQ
Stinger battery,alternator,wire,cap,fuse blocks
1 JL 12w6v2
1 7" monitor in rear
MB Quart 8" 4" and tweet in each door
Custom fiberglass,plexiglas, and aluminum amp rack
carbon fiber sub enclosure
Old 07-04-2004, 11:54 AM
Thanks a lot, I have an old piece of crap amp my dad had when he was my age, I dont really want to use it but I will if I have to. What are some good amps that yall would recomend for a kicker sub? Keep in mind Im on a VERY tight budget, lie $100-$150 max.
Old 07-06-2004, 12:35 AM
str8Subbin str8Subbin is offline
Send a message via AIM to str8Subbin Send a message via MSN to str8Subbin
i'll sell u my Kenwood amp for $90 i used it to power to 2 S12L5's u can bridge it at 4 ohms or have 2 channels at 2 ohms
