Old 04-12-2004, 05:44 PM
ViperJ's Avatar
ViperJ ViperJ is offline
Send a message via MSN to ViperJ
4 ohm? 2 ohm?
I recently got a Bazooka ELA300.1 amp. I was wondering how ohms is calculated. Does it have to do with the speaker or the amp. I havent got any subs yet but according to the specs 2 ohms is better.
4 ohm- 200Wx1
2 ohm- 300Wx1
Thanks in advance
White 07 STI, Bone stock for now
Old 04-12-2004, 06:11 PM
aznxthuggie's Avatar
aznxthuggie aznxthuggie is offline
Re: 4 ohm? 2 ohm?
4 ohm- 200Wx1
2 ohm- 300Wx1
Thanks in advance
im not 100% sure but for one thing, 2 ohm supposed to make 2X the power of the 4 ohm, lets say,
on a 2 channel amp
150 x 2 @ 4 ohms
300 x 2 @ 2 ohms
600 x 1 @ 4 ohms
on a 4 channel it should be like
50 x 4 @ 4 ohm
100 x 4 @ 2 ohm
Bridged 200 x 2 @ 4 ohm
on a class D it should be
150 x 1 @ 4 ohm
300 x 1 @ 2 ohm
usually people get 2 ohm subs because u can get more power out of it for cheaper, there are also dual voice coils that come in dual 2 ohm dual 4 ohm and 6 and on, when u have dual voice coils the subs are more flexible, and MUCH easier to worth with, all u gotta do is read how to wire subs online somewhere
Old 04-12-2004, 07:21 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
the ohm or impedance is determined by the speakers
Old 04-12-2004, 07:39 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: 4 ohm? 2 ohm?
http://www.automotiveforums.com/vbul...d.php?t=174537
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 04-13-2004, 09:02 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
Re: 4 ohm? 2 ohm?
half the impedance does not always mean its going to be double the power. That's usually the case, but not always. Viper: to get the most out of your amp get 2 single 4 ohm subs, one dual 4 ohm sub, or one single 2 ohm sub. Other combinations that would work is quad 2 ohm, dual 1 ohm, two dual 2 ohm subs. Wiring in series will give you the impedance of each coil muliplied by the number of coils, while parallell will give you the impedance of each coil divded by the number of coils.
Old 04-13-2004, 09:49 PM
ViperJ's Avatar
Re: 4 ohm? 2 ohm?
Thanks for all the help.
