Old 02-12-2004, 02:26 AM
Diesel2NR's Avatar
Diesel2NR Diesel2NR is offline
Send a message via AIM to Diesel2NR Send a message via Yahoo to Diesel2NR
Wiring a 2-ohm Sub
My Kicker CompVRs are Dual 2 ohm subs. When I wired them inside the box, I just connected both negagtives to eachother, as with the positives, then to the wire thingy (the clip things...you know...). I then ran a negative and positive wire to the amp, putting them one the bridged negative and positive. Now comes my question, that I've just thought of. Doesn't that make it 1 ohm per speaker now? Should I have run on voice coil to left and one voice coil to right?
Note: Each sub has it's own amp. My amps ARE NOT 2 ohm stable, which in all likelyhood, means they aren't 1 ohm stable, and probably explains why they keep going into protection mode if I turn the system up very loud.
Old 02-12-2004, 09:02 AM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Re: Wiring a 2-ohm Sub
http://www.edesignaudio.com/ep2/wiring.htm
www.cloudcity.deviantart.com
Old 02-12-2004, 09:43 AM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
You wired them in parallel, which is showing your bridged amp a single 1ohm load, which is showing each individual channel 1/2ohm. You REALLY should have researched some before trying to hook them up, and you're very lucky your amp still works.
You need to do this for each speaker
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 02-16-2004, 08:32 PM
Diesel2NR's Avatar
Thanks for the help guys. I put'em in a series and everything's much better now. I'm no longer thinking about sellin the system, cause now that it sounds good and the amps aren't overheating, I can't get enough of it.
Old 02-19-2004, 05:49 AM
MethodMan420's Avatar
MethodMan420 MethodMan420 is offline
You think it sounds good now, find a 1 ohm stable amp, use a sealed box and hear those speakers come to life. ( Or at least thats how I like it )
