Originally Posted by ottoracefan
I'm trying to decide which remote starter to install in my '98 Limited. There are so many brands/models available, I thought I would ask if anyone had a recommendation for/against any particular one.
I will be installing the system myself. I want to connect to the factory keyless entry and trunk release features, but am not interested in adding a security/alarm system to the car.
Thanks in advance,
Dale
I would recomend a unit from Directed Electronics (DEI). They seem to be the ones to get. They've kinda pioneered this market and have been #1 with Consumer Reports for the last several years. You can go to
www.directed.com and look at all the different kinds they have availible. I sell this brand and I will tell you that you can only buy the Valet, Hornet, and Rattler (to name some) out the door. Most others will have to be installed unless you find a dealer that's willing to sell it to you.
The install should be fairly easy for you as long as you understand 12v. vehicle electronics. Getting past the Passlock system can be a little tricky for amatures if you have it. Some of the Buicks still used the old VATS system with the black chip in the key. For that, you just need the right resistance which you can get at Radio Shack. Passlock, I suggest using DEI's # 555L since it is self learning. Just a few wires and you are done. Also, I suggest using 3M t-taps and fully insulated male spades to do the install. Otherwise, use solder with either shrink tube or 3m super 33 electrical tape.
