Old 12-22-2003, 01:38 PM
tcho1120 tcho1120 is offline
Some questions, Thanks!
Hi, everyone,
I have been here for awhile but I just registered and became a member.
I have the following questions and please help, thanks!
1. Do we need to sand the original paint (if there is orange peel) before we spray clearcoat on top of it?
2. the decals got pulled off by the masking type for one of my models. I firstly sprayed the paint, then decals, then decal softener, then clearcoat. Does anyone know which step(s) I have done wrong?
All helps are appreciated, thanks!
Merry Christmas
Old 12-22-2003, 01:43 PM
EMAXX's Avatar
EMAXX EMAXX is offline
Send a message via AIM to EMAXX Send a message via MSN to EMAXX
Re: Some questions, Thanks!
Welcome to AF!
1)If you would like the paint to look nice, you should sand it down, and smoothen it out, then shine it out.
2)I don't understand what you are saying. Why would you have masking tape over your decals? Could you please explain.
Old 12-22-2003, 03:02 PM
Acutally I firstly sprayed the paint on top of the primer and then I put the decals on. Afterwards, I sprayed about three layers of clearcoats. Lastly, I masked the body with masking tape and sprayed the window frames. However, some decals were pulled off along with the masking tape and I just couldn't figure out where I did wrong.
Thanks for your quick reply, really appreciate!
Old 12-22-2003, 03:04 PM
Ferrari TR's Avatar
Ferrari TR Ferrari TR is offline
Not A Hoarder!
1. yes
2. Sounds like the decals did'nt dry long enough before you applied the clear. Your masking tape may also be too tacky.
SCCA 7, The lost Z
Old 12-22-2003, 03:38 PM
EMAXX's Avatar
What kind of masking tape are you using? If it isn't Tamiya, you might want to get some. Also, like Ferrari said, it sounds like the decal didn't dry enough, or you soaked it too long and the glue came off of it.
Old 12-22-2003, 03:55 PM
Thanks, all,
Firstly, I used Tamiya masking tape since it's recommended by everyone here.
Secondly, I sprayed clearcoat about 1 week after I put the decals on.
In conclusion, I think the main reason is that I soaked it too long and the glue just came off of it.
Thanks all. It really helps a lot. I usually leave the decals in the water too long and I didn't realize it would make the glue come off. Thanks!
Old 12-23-2003, 09:40 AM
EMAXX's Avatar
Glad that we could help. How long did you soak them for?
A good way to soak them is put them with the decal down, and the paper up, and when the paper gets a little darker like it does, pull it up. Always seems to work for me. You have to watch closely, because it'll happen in about 10 sec.
please read this I have a important question .thanks. graygoose Riviera 10 07-19-2006 02:50 PM
just bought 95-F150 some problems, thanks! phil a F Series 1 01-21-2006 09:16 PM
A easy question, thanks zshuai 3000GT/Stealth 2 10-27-2005 08:10 PM
New 99 Camry owner with dash light questions, thanks max gurth Camry/Camry Hybrid/Vista 1 11-28-2004 11:12 PM
Just a few questions, thank you. GRiMRyDeR '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 9 10-26-2002 11:45 PM
