Old 12-18-2003, 10:53 PM
eillob's Avatar
eillob eillob is offline
347 vs 331
I 've been looking into dropping in a new engine. I like the specs I have found on the 347. However I keep finding myself talking to people who warn me about the problem with the rod pin being so high into the piston and the possibility of having early compression problems later on down the road.
Should I go ahead and go with the 331 and forget the 347? Or are these stories over exaggerated? My stang is not an everyday vehicle but I still want to be able to get on it without worry.
Old 12-18-2003, 11:37 PM
boosted331 boosted331 is offline
What are your plans for the motor, boost, nitrous, or N/A?
Old 12-19-2003, 01:39 AM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
The main knock I have heard agianst 347 is they get oil blowby on the rings cause of the the location of the rod pin. I never had a problem wit this on my 347 that I put 30,000 miles on. And we sell a lot of 347 at my shop that we build there and I haven't had anybody complain about it. And yes there are guys who have 100,000 miles on some of them.
If your going to FI, Nitrous it I get a 331, If you stay N/A I would def get a 347.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 12-19-2003, 07:08 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: 347 vs 331
If your going with a 347, I would suggest a CHP motor. The "Street Fighter" block uses forged pistons that eliminate the intersection of the oil ring and the wrist pin hole. This will help cure the oil blow by problems that some other 347's have.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 12-19-2003, 02:18 PM
Re: Re: 347 vs 331
The main reason the CHP 347's don't use oil like a typical 347 does is they use a shorter rod (think its 5.3" vs. 5.4" for a typical 347) which pulls the piston pin out of the oil ring. I've had a few friends with CHP 347 kits and they're doing fine with them, but I've had typical 3.4" stroke 5.4" rod 347's before that have used quite a bit of oil.
Old 12-19-2003, 04:07 PM
eillob's Avatar
Re: 347 vs 331
Eventually I would like to add on a 6 or 8psi supercharger. But that will be down the road right now I want naturally aspirated motor that will put me in high twelves at least. (94 mustang conv 5 spd)
331 or 347 stroker motor down86 Performance 4 03-12-2005 11:56 AM
347 rwhp miata for sale OneFastMiata MX-5/ Miata 3 01-14-2005 01:11 PM
347 bigbob Performance 9 11-21-2004 11:41 PM
347 stroker? lookin4wheels Mustang Talk 5 10-12-2004 09:49 PM
347 stroker or Holley Systemax? Boosted1 Mustang Talk 3 09-29-2004 09:17 PM
