Old 10-12-2004, 06:42 PM
lookin4wheels lookin4wheels is offline
Talking 347 stroker?
my engine has 150,000 miles on it and im looking at a rebuild sometime this winter. I was just wondering about getting a 347 stroker kit. They are on ebay going for $1500, thats a lot cheaper than forced induction. I was just wondering if this is a good idea for a daily driver car. How does this affect streetability. 400hp sounds bitchin to me
Old 10-12-2004, 07:10 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
With just a 347 lower end, theres no way you'll see 400 hp unless you upgrade evrything else too. I also would not buy a rotating assembly off e-bay, just my .02. Depending on what combo you put together, 347's are fine for the street, I have one. What car do you have?
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 10-12-2004, 08:51 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
There are some companies on Ebay that sell quality stroker kits using quality parts.
Remember besides the $1500 there is the cost of boring the block .30 over at the least. But many time the block also needs to be notched along the oil pan rails and sometimes other places depending on parts. Then if your not gonna assemble it yourself there is more money involved.
Also like said aboved a 347 shortblock with stock heads, intake, cam, is kind of like shooting yourself in the foot.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 10-12-2004, 09:00 PM
Re: 347 stroker?
The kit includes:
NEW Eagle 3.400" Forged Stroker Kit, PN: 14003
First quality kit, no blems, std/std, all new.
Eagle 3.4" 4340 Forged Steel Crankshaft, Internal balance
Eagle 5.400" 4340 Forged H-beam Rods w/ ARP bolts
JE SRP Series Flat Top +.030 Pistons, please inquire for different overbores, TW heads or dished pistons, we carry them all!
Clevite or Federal Mogul rod/main bearings
File fit plasma moly rings
I have a 1995 mustang 5.0 5 speed
Old 10-12-2004, 09:01 PM
Re: 347 stroker?
If Id have to get intake cam and heads, how much would that cost?
sorry im so ignorant lol
Old 10-12-2004, 09:49 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
plasma moly rings are a little overkill. they're designed for large amounts of nitrous or boost. in other words, huge amounts of compression. in excess of a 300 horse shot of nitrous or big boost. a step up from stock should do you good. chrome-moly rings i believe.
if i were you i'd find a local engine parts dealer and see if he'll give you jobber prices on engine parts. i'd go with either Eagle or Scat for the crank and rods, they make the best street parts. i was lucky enough to get hooked up by a local crankshaft guy and got a new set of rods for $350. $150 more would get a crank.
make sure the rods are set up for full-floating pins. no performance can be gained from that but you can assemble the entire engine at home with that setup.
also make sure the main and rod bearing sizes are consistent between the block, crank, and rods. sometimes in order to gain clearance for stroker applications, chevy dimensions are used. i had to exchange a set of rods because they had the ford bearing size while my crank has the chevy bearing size.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
