Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 11-07-2004, 03:21 PM
bigbob bigbob is offline
im thinking about a coast high performance 347 pro street short block set up for a blower. it comes with 8.5:1 compression pistons. i want to throw a set of afr 185's, gt40 lower intake and a kenne bell superchager on it. how much horse power can tha block handel? it has all forged internals. i want to no so i can decide on a boost level for the engine. thanks abunch
the craig
95 gt vert
built aode
underdrive pullies
slp cat back
bbk o/road h
nos dry 80 shot
Old 11-07-2004, 10:54 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Exact same kit I have. Well except I ordered the kit alone and put it in a Sportsman block. They use just a regular 5.0L on those unless you order them differently. So 500 hp is reasonable guess. I'd look into a main girdle system as a back up as well. If you order a good amount of stuff through them, they'll knock off a couple hundred if ya ask what kind of a deal you can get for it all. Good luck!
P.S. Check your compression ratio math before hand! That same kit on mine with TW heads actually makes about 8.9:1.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 11-08-2004, 08:04 AM
burly94gt burly94gt is offline
Re: 347
the craig
if it were me ide go w/ a larger intake. w/ as many horses as your plannen on putten out, an rpmII, track heat, or r-series intake would flow better numbers...thas just my opinion though
God said RWD, and all the little torque lovers of the world said, AMEN!!
Old 11-08-2004, 01:24 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Re: Re: 347
He can't do that if he is planning on a Kenne Bell. The Kenne Bell S/C is a twin screw not a centrifugal and is designed to sit on top of a stock lower 5.0/Cobra/GT-40 intake.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 11-09-2004, 10:35 AM
Re: Re: Re: 347
ahh ok, i didnt know that...see i learn something on here everyday whether it be important or not
Old 11-12-2004, 10:32 AM
Re: 347
they only use a regular 302 with their short blcoks? that sucks. what about droppin just the stroker kit into a dart block? that thing should handle more than i can throw at it right?
95 gt vert
built aode
underdrive pullies
slp cat back
bbk o/road h
nos dry 80 shot
Old 11-12-2004, 01:11 PM
GTStang's Avatar
Stang Guy
Re: Re: 347
They all(D.S.S., CHP, etc..,) use stock blocks as the base, they will also by request use FMS/Dart blocks etc.., if you ask them. But man that is some serious cash your looking into.
The worst thing FMS ever did is stop making the A4 block it was the best combination of affordablity and strength. Instead of an R302 or Dart block I might look to find a good used A4 unlesss your really want a 1,000+HP monster SB.
Old 11-21-2004, 05:05 AM
NIN881 NIN881 is offline
Re: 347
What is the b50 block? I've also heard of a mexican block, is it the same block? From what I heard you can put 700 though those.
1994 Mustang GT, TFS TW heads, TFS street heat intake, Pro 5.0 shifter, BBK LT headers, BBK short off road H, Mangnaflow catback, FMS 3.55 gears, TFS 1.6 rr, JMS chip (soon to be replaced by a tweecer).
Horsepower sells cars, torque wins races.
Old 11-21-2004, 04:17 PM
boosted331 boosted331 is offline
Re: Re: 347
B50 is a FRPP Sportsman block. I've seen both side-by-side, and they both look VERY similar. The mexican block has withstood 700+ horsepower, so I don't see why the B50 shouldn't be able to take atleast as much as the mexican block.
Old 11-21-2004, 11:41 PM
Re: 347
How much does the b50 cost? Sounds like that block would suit me perfectly. I want 400-600 hp.
