Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 03-09-2005, 08:26 PM
down86 down86 is offline
331 or 347 stroker motor
Need help what kind of heads,carb,and other goodies should i use when using one of these stroker kits 331 or 347? Does any one have one of these set up on there mustang ? What parts did you use? Any help would be great.
Old 03-09-2005, 09:08 PM
benchtest benchtest is offline
Re: 331 or 347 stroker motor
A friend has an '88 LX with a 347. Heads are Canfields (Light port work by myself, 1.94/1.50 valves, flowed great out of the box...just cleaned up and smoothed radius'), 750 carb, solid lifter cam (specs. I'd have to ask), around 10.3:1 comp I believe, can't recall other specs, but could ask. Auto., lauching at 3500, 4.10 rear, 2600 lbs dry, ran 10.60 1/4. I've flow tested many types of heads (stock 5.0 to trick flows, and even hemi's)...very impressed with Canfields. Keep it all matched and find someone who really knows heads in your area. A good rear suspension (toss the factory lower arms and get some that correct the instant center point), and a rigid chassis are a must. Good luck.
Remember: Don't confuse noise with horsepower! and Junk is junk, even when it's on sale!
"I would never doubt your expertise....it's obvious you wrote the book on stupidity!" DD
Old 03-10-2005, 10:12 PM
tturnpaw's Avatar
tturnpaw tturnpaw is offline
Send a message via AIM to tturnpaw Send a message via MSN to tturnpaw
My 82. U can see the stuff at the bottom. the biggest gains r from Edelbrock Victor jr heads (or brodix) and a holley double pumper carb. dont go edelbrock with the carb (they r 2 streeetable and emission carbs) 3.73 in rear 4 street. 347 is a better stroker of course. stronger 4 what i heard. racing cam. i bought a x303 on my stock bottom end. thats about it. good clutch 2.
1982 Mustang GT- roller motor x303 cam, GT40s, MAC/Spintech exhaust MSD ignition, Edelbrock Carb, Ford Racing roller rockers
1994 Escort 2DR LX - cone air, 3.8L throttle body, FUTURE SPI turbo swap
Cops: You can race, but Im impossible to chase!
LS WHAT?
Old 03-11-2005, 12:54 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
If you are going to stay N/A, I would go with AFR185s, and run a fairly high compression. If you are going to use boost, build with a lower compression, and use 205s.
These guys know their shit!
http://www.adperformance.com/heads_afr_ford_sbf.html
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 03-12-2005, 11:56 AM
boosted331 boosted331 is offline
I got my block from AD Performance, that's a great place to go.
