Go Back   Automotive Forums Car Chat > Hyundai > Tiburon | Tuscani
Old 12-16-2003, 11:48 AM
ColeIketani's Avatar
ColeIketani ColeIketani is offline
Send a message via AIM to ColeIketani
Compression Ratio?
Would someone mind explaining that term to me please? thanks
2003 Hyundai Tiburon: Injen CAI, Mussa Single Exhaust, Sparco Four Point Harnesses, RRM Front and Rear Strut Bars, 22mm Rear sway bar, Shark Racing Pedals, Painted Rims.
Saving for: Either Big Brake Kit, lines etc, Tien Coilovers Sparco Speed Seat for driver side.
Old 12-16-2003, 02:00 PM
Adam_Hunsicker's Avatar
Adam_Hunsicker Adam_Hunsicker is offline
Re: Compression Ratio?
hmmm... don't know a great deal about this subject but my understanding is that compression ratio is generally read in pounds of pressure per cubic inch... here's an example... if you see compression ratio of 10.3 that means there is 10.3 lbs of pressure for every cubic inch of space in your combustion chamber.
Old 12-16-2003, 07:19 PM
hmm, so what does that mean preformance wise? does anyone know?
Old 12-16-2003, 08:45 PM
tibby01 tibby01 is offline
allright here goes,
compression is how tightly packed the air is in the engine. say your engines compression ratio is 10:1(10 to 1). this means that the pistons compressed the air/fuel mixture 10 times its original pressure. the higher the preesure, the more excited the molecules get, resulting in a more violent explosion.
this is why low compression pistons are used in turbo engines. the air pressure going in is already pretty high, so if the pistons compress it anymore, it could explode prematurely, causing a condition known as "knock". this is bad, because it will cause the piston to move the opposite way when it is not supposed to causing your engine to go BOOM. so not only do you use lower compression pistons, you use a higher octane fuel. a fuels octane rating is its resistance to burn, so a higher octane fuel also helps in preventing knock.
Old 12-16-2003, 09:31 PM
wow you learn something everyday. So what about ratios that are 10:3 (using the Tibs for an example) what does that mean? (10 times 3 times the pressure? "I know I am wrong" lol)
Old 12-16-2003, 10:18 PM
first off, it is not 10:3, it is 10.3 which means 10.3:1. if it were 10:3, this means that since pressure of normal air is 14.7psi in the atmosphere, you find the compresion coeficcient 10/3= 3.33333. this is the same as 3.3333:1. so the pressure at TDC(top dead center or the highest point of the piston) is around 14.7x3.3333= 49 about.
most of the time, compression ratios are just one number, because it is commonly known as being "X:1", so the ":1" is not necessary. i have never even seen a compression ratio of Xa number other than 1), but im sure it exists to indicate very precise measurements.
compression ratios and method of compression SPOOK(I) Impreza/9-2x/Outback Sport 2 05-28-2013 06:26 PM
Compression Ratio = Gear Ratio?? The LH Engineering/ Technical 8 04-23-2006 10:10 AM
Compression Ratios....drift..your sarcasm welcome hehe VTEC_boi Engineering/ Technical 16 03-18-2004 06:30 PM
how to lower compression ratio? liquid8 Forced Induction 5 03-11-2002 04:59 PM
compression ratio b16b bomber '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 01-23-2002 12:47 AM
