View Poll Results: Which is the better turbo?
Evo III 16g 5 62.50%
t3/t4 turbo 3 37.50%
Voters: 8. You may not vote on this poll
Old 12-10-2003, 04:53 PM
Afrokid's Avatar
Afrokid Afrokid is offline
Send a message via AIM to Afrokid
Arrow t3/t4 turbo vs. Evo III 16g turbo
which do u believe is better...the Evo III 16g turbo or the t3/t4 turbo?
Old 12-10-2003, 05:07 PM
NeonblueEclipse NeonblueEclipse is offline
Send a message via MSN to NeonblueEclipse
Re: t3/t4 turbo vs. Evo III 16g turbo
t3/t4 turbo ALL THA WAY !!!!!!!
Dustin
GSX baby!!! ALL THA WAY
Old 12-10-2003, 07:10 PM
AmericanEagle's Avatar
AmericanEagle AmericanEagle is offline
Send a message via AIM to AmericanEagle
Re: Re: t3/t4 turbo vs. Evo III 16g turbo
Whats the diff between an EVO 3 manifold and stock 2g? I can't see a differance
1997 Eagle Talon TSI AWD A/T "Never Lift To Shift"
Injen Filter - Forge Motorsport BOV - Magnecor 8mm Race wires - NGK BPR7ES - Apex'i N1 - Joe p MBC - Modified Dejon "L" Pipe
Old 12-10-2003, 08:44 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: Re: Re: t3/t4 turbo vs. Evo III 16g turbo
GReddy 18G!!!!!!
Old 12-10-2003, 09:14 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: Re: Re: Re: t3/t4 turbo vs. Evo III 16g turbo
Originally Posted by BoostedSpyder
GReddy 18G!!!!!!
screw that, they are worthless, i'll stick with my 20g!
Old 12-10-2003, 09:31 PM
duckydsp's Avatar
duckydsp duckydsp is offline
Screw all of those! I like my..... wait, I don't have a turbo. I'm gonna go cry now. Saving for HRC
DSF
1998 Green Mitsubishi Eclipse GS- Vibrant Ram Intake, Greddy Evo2 cat-back, front and rear strut bars.
2 Kicker L7s, amp coming soon
17" white Motegi RT5 rims, Quwhees 12-piece wide-body kit will be put on....... someday
Old 12-11-2003, 11:52 AM
kjewer1 kjewer1 is offline
AF - Advisor
I have posted this SEVERAL times here, but I guess I'll do it again. t3/t4 says nothing about the turbo. Just that it has a t3 exhaust side, and a t4 compressor side. Most of the "t3/t4" turbos cant even be compared with a 16g at all. The 16g is tiny. The largest t3/t4 is massive and will support double the power. Even the 20g is only a little bigger than the smallest t3/t4. The 16g will move similar air to a 46 trim, but its maxed out at that point and ineficient.
The correct way to ask about such a mismatched pair, is what turbo is better for a specific situation. The 16g is better for people that cant (or dont want to) afford to support a t3/t4, and go through all the learning required to run a large turbo
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 01-01-2004, 10:31 PM
will2shower will2shower is offline
Send a message via AIM to will2shower
ok. kind of t3/t4 turbo would spool as fast as a 3vo 16g? and if there is one would it be able to give more power?
Old 01-01-2004, 11:00 PM
AF - Advisor
I dont think any t3/t4 will spool as quickly as a 16g, at least not with a "normal" exhaust side setup. The smallest t4 wheel people typically use is the 50 trim, and its almost invariably mated to a stage 3 wheel and .63 AR housing. That gets you to 20-25 psi before 4000 rpm, which isnt laggy if you ask me, but its still at least 500 rpm "slower" than the 16g spoolup. In my opinion, the gains you get from a 50 trim sized turbo well outweigh the extra lag. I launch at 5500 rpm, and never go below that for the whole race. So I dont even see my 4400 rpm spoolup as a problem But thats just me. Like I always say, if you are having turbo lag prblems, downshift.
Kevin Jewer
Old 01-01-2004, 11:09 PM
Thanks for the info, the reason i would like to have the quick spool up is because i would like to get into autocross. And for what i have heard, the most t3/t4's give excellent power, but with the power comes the lag which is a big hurt on the track. don't get me wrong i would definitely like to have a quick ET but anyway.. i guess il just keep looking around.
Old 01-01-2004, 11:32 PM
AF - Advisor
I've seen people autox with very good success with a 20g clipped 20 degrees, lol. But if quick spool is what you need, I would stick with the EVO3 16g. Check out www.slowboyracing.com for a comparison between that and the typical big/small 16g. People are moving 44 lbs/min on that turbo, and trapping at or near 120 mph. Still spools quickly. Cheap money too, 569 last I looked. SBR and FP sell it as far as I know.
Kevin Jewer
Old 01-02-2004, 04:50 PM
thanks for the info. one more question, if i got the evo 16g from sbr, which is a pretty damn good price, and got it ported. do you think i should get it clipped? because i thought clipping gave you more lag but more power in higher rpm's
Old 01-02-2004, 05:24 PM
AF - Advisor
Clipping isnt worth it. I dont think anyone has ever gained measureable power increase from it. Now, something like a TDO5 20g with a 20 degree clips is a whole other story. Thats trying to make up for an overworked turbine wheel, etc. I would just get it ported. And stick with the stock sized flapper if you plan to run over 20 psi boost (who wouldnt? )
Kevin Jewer
Old 01-02-2004, 05:43 PM
20 psi on stock internals? could i do it with 16g
Old 01-03-2004, 07:22 AM
mitsu_eclipse95gst's Avatar
mitsu_eclipse95gst mitsu_eclipse95gst is offline
im running 18 on mine
EVO III 16g turbo TheRomer Engine, Transmission and Drivetrain 13 11-08-2005 07:24 PM
I need a turbo, big 16g, small 16g or evo III 16g awdpower Off-Topic 8 08-04-2005 07:19 PM
Big 16g, small 16g, or evo III 16g. What to choose awdpower Off-Topic 13 07-29-2005 10:48 AM
EVO III 16g turbo !!!!!!! buying quick quest baker1234 Off-Topic 5 05-31-2005 08:58 PM
16G vs. Evo III Turbo Afrokid Off-Topic 8 11-28-2003 10:04 PM
