Old 07-28-2005, 10:25 AM
awdpower awdpower is offline
Send a message via ICQ to awdpower Send a message via AIM to awdpower Send a message via Yahoo to awdpower
Big 16g, small 16g, or evo III 16g. What to choose
Which one would you guys reccomend for someone that wants to race.
1995 GSX RACER
Old 07-28-2005, 10:52 AM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
lol. You have to be more specific than that. I would go though either with the Big 16g or the Evo 16g(maybe even the GT ) But anything will be better than the t-25. I think the EvoIII 16g is good for up to 400hrspwr, the GT up to 380 and the Big 16g for 380 and then the small 16g at 340. It's just going to depend on how it's going to be used and how deep your pockets are
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 07-28-2005, 11:22 AM
Re: Big 16g, small 16g, or evo III 16g. What to choose
so the evo III is better than the big 16g
1995 GSX RACER
Old 07-28-2005, 11:23 AM
Re: Re: Big 16g, small 16g, or evo III 16g. What to choose
I need a turbo quick but im not just going to spend it on something that is not worth it. You guys think that the t28 is alright
1995 GSX RACER
Old 07-28-2005, 12:11 PM
Turbodog97's Avatar
Just a Neon
A while back when I was "turbo shoppin" I came accross the T-28 but all the feedback I got from it is that it would be better just to get the EvoIII. Think about it this way: the T-28 does bolt right on with no mods but it costs a couple hundred more and yields less power potential. The EvoIII(most common upgrade) costs a couple hundred less and gives out more power. Either way you cant just bolt up a new larger turbo and expect a huge power increase. To get the most out of it you will have to get new injectors, fuel pump, some sort of afc and etc.
05 Srt4
97 Mx-5
Old 07-28-2005, 12:15 PM
So what turbo would you reccomend would be better the big 16g or the evo III 16g
1995 GSX RACER
Old 07-28-2005, 01:31 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Go with the EVO III 16g. It holds it's resale value very well, so if you decide to upgrade down the road you will get top dollar. Stay away from the T-28...it costs more than the EVO III + install kit and yeilds a lower airflow. It is designed more for people that want to retain the stock look.
The EVO III has a 2.5" turbine outlet vs. 2" on the big 16g. The compressor wheel is slightly larger but lighter than the big 16g wheel. Also, the entire turbo itself is lighter. It also flows more air.
Small 16g flow = 34 lbs/min
Big 16g flow = 36 lbs/min
EVO III 16 flow = 42 lbs/min
All that, and it's only about $10 more than the big 16g.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 07-28-2005, 01:47 PM
Turbodog97's Avatar
Just a Neon
hey spyderturbo how is it you have the evoIII and the supporting mods but only 242horsepower?
05 Srt4
97 Mx-5
Old 07-28-2005, 01:51 PM
Where would be the cheapest evo III i could get. I would also have to get a install kit to go along with that right.
1995 GSX RACER
Old 07-28-2005, 03:09 PM
Turbodog97's Avatar
Just a Neon
Alright Slow boying racing has one for $569 plus $199 for install kit. Turbochargers.com has one for $550 plus a $125 install kit.They also have cheaper ones one ebay for around $525.
05 Srt4
97 Mx-5
Old 07-28-2005, 04:51 PM
Nayr747's Avatar
Nayr747 Nayr747 is offline
Uh oh, you mentioned slowboy. Spyderturbo007 will probably tell you not to get it installed there since they f-ed his up.
'99 GSX, 5-speed, 60k miles: Greddy filter / RRE uicp / 1g bov / Autometer boost gauge / Injen-copy intake / Megan DP (not installed)
Coming soon! Thx to Blackcrow & nova1313! http://dsm-one.org/
Adopt pets in need! http://www.petfinder.com/
Old 07-28-2005, 07:45 PM
joemathews's Avatar
joemathews joemathews is offline
I think the T28 is an underrated turbo, personally. Everyone and their brother will tell you to get the EvoIII, but if you get a good deal on a T28, you can do a lot with it as well. For one, it spools a little bit faster than the EvoIII. Sure, people claim it's only 200 rpm faster, or whatever, but I think there is a bigger difference than that.
Some guy on Tuners ran a 12.3 on pump gas in his 2g awd with a Big T28. If you are going to get a T28, make sure it is the FP Big T28. The others are significantly inferior turbos to 16gs.
As for the 16gs, if you're buying new, it makes sense to get the EvoIII 16g, just as everyone here has said. It just flows more air than the others.
1996 Eagle Talon
Old 07-29-2005, 06:51 AM
I have certain "issues"
The biggest problem I have is that I refuse to upgrade the stock catback. I have a DP and race cat, but the stock cat back is a huge bottle neck. Also, I haven't upgraded my UICP yet (that should be comming in the mail soon )
I am also still on the SMIC as opposed to a FMIC. I am ordering water injection when I get back from vacation and should have the WI and the UICP installed in about 3 weeks. That should make a huge difference.
Look closely at the ebay turbos and you will see that they are a "knock off" and aren't genuine MHI turbos (You can tell because it says EVO III GT on the compressor housing). There are mixed views on these turbos as far as life, flow, composition, etc. I don't have any personal experience with the GT, so I'm not going to comment. You can read all about that on tooners.
1997 Spyder GS-T
5-Speed
Old 07-29-2005, 10:48 AM
Turbodog97's Avatar
Just a Neon
I ordered the GT version(hopefully curiousity won't kill the car and should be putting it on today or tomorrow. I'll let ya'll know how it performs and lasts.
05 Srt4
97 Mx-5
