Old 12-03-2003, 01:55 PM
churchboy churchboy is offline
Right rear turn light out
I figured my fix was going to be quick. On my 99 suburban, the turn signal indicator on the dash started blinking quickly only when signaling a right turn. I figured this ment a bulb was burned out. I replaced all the bulbs and I still have the problem.
The front right turn lights are working (although they do blink fast) but the rear lights do not light. The rear brake/running lights do not work on this side either. The reverse lights are working.
Any help would be Great!
Thanks
Old 12-03-2003, 05:44 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Right rear turn light out
Replace the rear circuit board
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 12-08-2003, 02:43 AM
EFFENDI EFFENDI is offline
same problem
the exact same problem is happening to me. i tried replacing/switching bulbs. i have a 1997 LT 1500. replacing the circui board is a little vague of a description on how to fix it. i dont want to take it to the dealer...
Old 12-08-2003, 06:27 AM
GMMerlin's Avatar
I know stuff
Re: same problem
The rear circuit board is what the bulbs plug into,then is attached to the rear lens assembly.
Whats wrong with dealers?
GM WCT
PM Me for details
Old 12-08-2003, 03:38 PM
they charge too much to fix anything!
Old 12-11-2003, 02:46 PM
dirty dan dirty dan is offline
The lamps plug into the circuit board. These fail commonly. I had to replace one on my Mom's yukon and I think it cost about $50.00. Pull out the whole assy. You'll see how the circuit is made in. Usually it's burned close to where the circuits intersect. This can be soldered for temp repair, but it probably won't last.
Old 12-12-2003, 01:14 AM
got it fixed
went to the mechanic and dropped it off for routine maintainance. i mentioned the problem and told him there was 20 extra dollars in it if he could fix it. i went off in my other car and came back to find it fixed. he was off duty by the time i came back. he didnt charge me anything for fixing it. but i missed the whole procedure. if i can find out what he did i will post it.
2000 jimmy slt 4x4 rear running light out (Bulb is good) Lonnie 4x4slt Problem Diagnosis 1 02-11-2010 07:55 AM
right rear turn signal out koolz68 Cavalier Problem Diagnosis 1 09-01-2008 02:42 PM
2005 Malibu Max Break Lights and Rear Turn Signals Out SmiJTP Malibu 1 05-27-2008 03:54 AM
1996 sebring convertible right rear turn signal does not flash berko70 Sebring | Sebring Coupe | Convertible 3 01-03-2007 12:46 PM
Right rear turn signal silly boy Windstar 3 06-30-2006 09:06 AM
