Old 02-10-2010, 10:42 PM
Lonnie 4x4slt Lonnie 4x4slt is offline
2000 jimmy slt 4x4 rear running light out (Bulb is good)
I need some input from you guys.
My 2000 Jimmy slt has an issue. The passenger side rear running light is out, and its not the bulb. The wire behind the assembly isnt getting power. The brake light and signal works. The driver side taillight and sigs work fine. Turning on the hazards still doesnt make the passenger side rear runner work.
What do u guys suggest? I was hoping it would be the recalled hazard switch, (free fix) but its not looking like thats the case huh? So what else could it be???
H E L P ! ! !
Old 02-11-2010, 07:55 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 2000 jimmy slt 4x4 rear running light out (Bulb is good)
H E L P ! ! !
GET A WIRING DIAGRAM AND TRACE THE WIRE BACK TO WHERE IT IS LOSING 12 VOLTS.
Is the running light by the tail light or separate?
You may be able to tie it into tail light wire.
MT
Tags
jimmy , light , runner , taillight
