Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 11-03-2003, 05:56 PM
darbykidd darbykidd is offline
fan not blowing
Hi. I have an 88 olds cutlass cierra and the fan hasn't worked for about a year now. I put up with it last winter but I don't want to do another year. It will produce heat but of course the heat only comes out when I get going about 30 mph or so. Is there a fuse that controls this because I couldn't find one. What else could be the problem and how do I fix it or do I need to take it to a repair shop. thanks for the help.
Old 11-27-2003, 04:17 PM
shekky shekky is offline
Banned
Send a message via MSN to shekky
Re: fan not blowing
there is a fuse for the fan, but after you check the fuse, (if its ok) take a wire and run it to the fan from the battery. make sure the fan works
Old 11-27-2003, 07:35 PM
Thanks for the help Shekky, Where exactly would this fuse be and what would it look like? I couldn't find one in the fuse panel unless its under some other name. Thanks again for the help.
Old 11-27-2003, 09:24 PM
Banned
Re: fan not blowing
usually it under a/c. there should be two of them. one of those two will be it.
Old 11-27-2003, 11:44 PM
under the a/c compressor? What would the fuse look like. I'm not very knowledgeable about this so I appreciate your help. I'd like to save a costly trip to the repair guy if I can fix this on my own. thanks again.
ford E350 heater fan not blowing az-n-need E Series 5 10-10-2005 04:23 PM
Heater fan not blowing right Cavibroke Cavalier 5 10-05-2005 09:55 PM
A/C fan not blowing as well on max thughey Suburban 4 07-27-2005 10:54 AM
Fan not blowing correctly. bbeaven Impala | Impala SS 2 12-13-2004 04:09 PM
AC/Heater fan not blowing go2ml 5 Series 4 05-04-2004 07:53 PM
