Old 08-09-2003, 01:18 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Ohms?
I heard somewhere that wiring 2 speakers to 2 channels positive, positive, negative negative is still a 4 ohm stereo load, I have 2 SVC subs 4ohms each and I was wondering how to get a 2ohm stereo load, if possible for the subs
Old 08-09-2003, 04:35 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
When wiring subs you always have 3 choices, series, parallel, or just straight + to + and - to -. The choice you make depends on your subs and amp mainly. To calculate the final ohm resistance of a series setup, you just add the ohms of each component in the series connection (2 4ohm subs = 8ohm final load). To calculate the final resistance of a parallel setup you take the inverse of each component and add them together, then you take the inverse of the answer (inverse of 2 4ohm subs = 1/4 + 1/4 = 1/2, so the final load is the inverse of 1/2 which is 2ohms). The third choice is the simplest, basically you have a 4 ohm sub, you hook it up to the amp and you have a 4ohm load. It is impossible to have 2 4ohm subs and have a STEREO 2ohm load. In order to have a stereo setup you have to wire each sub individually, which means you would have to have a 2 channel amp and wire each sub to each channel, which means you would have a 4ohm load on each channel. If you wanted a 2 ohm load then you would simply wire the subs in parallel and bridge the amp (or if it's a mono amp then just hook it up to that 1 channel), completely eliminating the stereo setup.
However, having stereo is pointless when you're talking about subs, because they're omnidirectional. If you have a sub on the right and a sub on the left playing the right and left channels respectively, you won't be able to tell the difference at all because the bass just mixes together and forms 1 sound. And I guarantee you if you have 2 subs in the trunk playing stereo, you would NOT be able to hear the right sub and the left sub as the right and left, it would just be weaker bass when only one channel is playing.
If you want a 2 ohm load and you have a 2 channel amp your only option is to bridge the channels and wire the subs in parallel (just make sure your amp can take a 2ohm load when bridged)
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 08-09-2003, 04:49 PM
Haibane's Avatar
basically what I already knew, just hoped you would tell me different, lol
Old 08-16-2003, 05:25 PM
SC300LeXuS SC300LeXuS is offline
Re: Ohms?
one thing, im pretty sure you got the series and parallel Ohm equations backwards, 2x4ohm subs wired in series =2ohms, 2x4ohm subs wired in parallel =8ohm, direct wiring 4ohm = 4ohm
Old 08-16-2003, 08:42 PM
GSteg's Avatar
GSteg GSteg is offline
Send a message via AIM to GSteg
no..he got it right.
2 SVC 4ohm wired in series=8ohm
2 SVC 4ohm wired in parallel=2ohm
I love them sub wufers
Old 08-17-2003, 12:59 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
parallel ... depends on how the DVC is wired per speaker
if each DVC sub is wired in series .... each sub will be 8 ohms
if you wire these two in series it will be 16 ohms
if you wire these two in parallel it will be 4 ohms
if each DVC sub is wired in parallel .... each sub will be 2 ohms
if you wire these two in series it will be 4 ohms
if you wire these two in parallel it will be 1 ohms
DVC's just give you more flexibility in wiring
what is difference dual 4 ohm dual 2 ohm Mustang_95_Coupe Car Audio 28 10-07-2004 11:02 PM
Converting 4 ohms to 2 ohms CRXsiZCpa Interior | Audio | Security 3 08-31-2004 08:32 PM
Which is better 2 ohm or 4 ohm subs jackjordan86 Car Audio 4 07-06-2004 12:35 AM
4 ohm? 2 ohm? ViperJ Car Audio 5 04-13-2004 09:49 PM
Can i run 4 ohm subs at 2 ohms? ripcurlguy Car Audio 2 12-28-2003 09:45 PM
