Old 08-24-2004, 10:26 PM
Mustang_95_Coupe Mustang_95_Coupe is offline
what is difference dual 4 ohm dual 2 ohm
PLMK thanks
Old 08-24-2004, 10:29 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Do a search for your question and quit wasting our time.
I know it is on here.
www.cloudcity.deviantart.com
Old 08-24-2004, 10:35 PM
Re: what is difference dual 4 ohm dual 2 ohm
heres what i get when i try to search
The search term you specified (4) is under the minimum word length (3) and therefore will not be found. Please make this term longer.
If this term contains a wildcard, please make this term more specific
if anyone else would be kind enough to help thanks in advanced
Old 08-24-2004, 11:34 PM
TFFantasy44 TFFantasy44 is offline
A dual 4 ohm can be wired down to 2 ohm or 8 ohm, and a dual 2 ohm can be wired to 1 ohm or 4 ohm. Use it to pick an amp that suits the sub well - e.g. if you have a 2 channel amp that can be bridged to 4 ohms, you will want the dual 2 ohm so you can get the most out of your amp. Go to www.bcae1.com and read everything there.
Old 08-24-2004, 11:36 PM
thank you man your a beast looks like ill get the 2 ohm i have this amp
Audiobahn A2200HCT 2 Channel High Current 1600W RMS Amp
Old 08-24-2004, 11:41 PM
Yup the 2 ohm is what you need. What subs are you looking at?
Old 08-24-2004, 11:43 PM
Brand: Kicker RMS Wattage: 600
Model: 02S12L5 2OHM Voice Coil: Dual
Old 08-25-2004, 12:07 PM
Haibane's Avatar
Sorry about that...
You might need to upgrade your alternator for that amp... since it is a class A/B and pulls a crap load of power according to its rating... I could be wrong though.
Old 08-25-2004, 04:50 PM
ok what else would i have to do. I was gonna buy a capictor too also.
Old 08-25-2004, 09:53 PM
Haibane's Avatar
caps are pointless
Old 08-25-2004, 10:01 PM
really why? i was reading in a mag and saw the speical alternators but i thought caps did the same thing
Old 08-25-2004, 10:44 PM
Haibane's Avatar
HAHA... HA... Alternators give power, caps take power. that is as simple as I can put it.
Old 08-25-2004, 11:02 PM
alright what brand would you recomend?
Old 08-25-2004, 11:28 PM
Haibane's Avatar
for an alternator... try mean machine...
Haibane's Avatar
my bad, mean green http://www.mean-green.com/
