Old 06-30-2003, 10:13 AM
jimmy53 jimmy53 is offline
Blower only works on 5
My interior fan only works on setting 5. Everything else is working fine, like the heat and A/C, just not fan speeds 1-4. Any ideas as to what the problem is, and how I can fix it? Thanks.
Old 06-30-2003, 01:59 PM
rubberman rubberman is offline
I say the switch is bad.
2000 Grand Prix GT w/ gold package.
K&N CAI intake, U bend delete, ZZP PCM, Ractive oval exhaust tips, ZZP 3" downpipe
2004 Chevy Trailblazer EXT
Keep on Keeping on...
Old 06-30-2003, 06:32 PM
That's what I thought the problem may be too, but it's not. I know this because I changed the switch from my girlfriends Grand Prix to test if it was the switch. Her switch doesn't work in my car, and my switch does work in her car, meaning the switch is ok. Does anyone have any other suggestions?
Old 06-30-2003, 08:12 PM
I would try asking the question at:
GrandPrix.net forums
Grand Prix Owners Forums
those 2 places are great for finding info and stuff - try there.
Old 07-01-2003, 07:38 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Speeds 1 thru 4 go thru a blower motor resistor mounted forward of the blower motor underneath the passenger side hush panel. Speed 5 doesn't go thru the resistor. I have changed at least 100 of these in the last few months. The problem is the resistor ets wet and shorts out. Replace the resistor with the updated part from GM!
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 02-05-2006, 11:32 AM
84fordgt 84fordgt is offline
Thumbs up Re: Blower only works on 5
To Flatrater -
Thanks alot for your tips on this problem - it saved me a ton of time. I was
able to remove the resistor and repair it the corroded circuit traces on the
resistor printed circuit board. I'm viewing this as a temporary fix until I get
the replacement part.
Did the part mfg update the part to make it more robust, like maybe cover
the entire part with a durable plastic or epoxy that would prevent moisture
from corroding the circuit traces?
Thanks again.
Old 02-06-2006, 09:30 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
The new resistor is an improved design that addresses the corrosion issue. The AC DElco part number is 15-80571.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Climate blower only works in high BriBird93 Thunderbird 7 12-23-2005 10:15 AM
Fan Blower only works on High Twachs M Bodies 4 01-03-2005 06:21 PM
Blower only works on high ?? ms5star Cherokee 7 11-17-2004 09:19 PM
Heater/AC blower only works on high. 1992 rkkennard Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 4 05-11-2004 07:55 PM
A/C blower only works on 3 and 4 setting egbcrx '88 - '91 Civic | CRX | Wagon | Shuttlee 1 02-29-2004 10:17 PM
