Old 12-28-2004, 09:03 PM
Twachs Twachs is offline
Fan Blower only works on High
I have a 98 astro and the Fan Blower only works on High, 1,2 and 3 do not work. I checked the fuses and they are ok. Is there a low speed fan relay somewhere?
Please Help.
Tim
Old 12-29-2004, 08:59 AM
VABchRick VABchRick is offline
Re: Fan Blower only works on High
You either have a bad resistor block or the fan speed selector switch is bad. The resistor block is under the hood on top of the box that has the A/C coils (Left side).
Good luck
Old 12-29-2004, 10:08 PM
Thanks, I will take a look. Is there any way of jumpering the resistor?
Old 12-30-2004, 07:34 AM
If you jumpered the resistors, you'd just get High speed anyway. The block runs less than $10.00. If I remember correctly, I found it at Advance Auto. One plug connector (Approx 5-6 wires to it) and two screws and it was done.
Old 01-03-2005, 06:21 PM
vintech72 vintech72 is offline
your blower motor resistor is no good
high speed fan runs thru a relay and not
thru the resistor
