Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 06-09-2003, 06:06 PM
maverick_tha_man maverick_tha_man is offline
Angry '90 eighty eight STALLING
I have a 1990 Oldsmobile Eighty Eight Brougham Royale with a 3.8L V-6, and very often when i'm driving, the car stalls. It happens when i turn the car off after when the engine has been running, and start it up a few minutes after, BUT, if i keep trying to start the car after, it wouldn't start till one of the sensors kicks in and sets the idle, and it never stalls after that till i turn it off. I would think its a sensor, but every car on this forum that has the same engine in the same years 88-93 with the same stalling problem can not find a solution. I'm sure its not an electircal or any other problem, but a throttle problem. Any help would be great.
Old 06-10-2003, 09:47 PM
pcv pcv is offline
Try and scan the car for codes. Actually you can pull the codes by jumping A & B on the ALDL connector situated below the driver side kick panel. You have to know how to read the flashes. If you get code 41, which is your crank sensor, replace it. It will cause your no start when hot.
As for stalling, you may have another problem. That should be verified by checking for spark after it stalls. If no spark, replace the ignition module. I've done a few of those now that the weather is getting warm. Good Luck.
NOTHING LIKE AN OLD CAR.
Old 06-10-2003, 10:08 PM
GM_man GM_man is offline
need a new engine
Old 06-25-2003, 07:54 PM
carquestman's Avatar
carquestman carquestman is offline
Send a message via AIM to carquestman
not starting
could be a fuel pump relay....there are 2 of them
one primes the fuel pump whene you first turn on the ignition
the other one kicks on whene the oil pressure switch has proper oil pressure
if the first relay has gone bad and isnt priming the fuel pump your car would crank until oil pressure comes up then the fuel pump would come on and the engin would start happy hunting
Old 04-16-2004, 09:36 PM
wierd1001 wierd1001 is offline
Send a message via MSN to wierd1001
Re: not starting
Mine stalled once or twice the first time you would pull it out of park in the morning. then it ran fine the rest of the day other than a little bit of rough idle. I quit gassing up at shell and stopped using cheezy walmart injector cleaner and it never did it since. That was last year.
Coincidence?
Old 04-17-2004, 02:48 PM
Creative Creative is offline
Re: '90 eighty eight STALLING
Try pulling off the Idle air controler (( little round object with two wire and two screws holding it to the throttle body )) and remove it and spray it down with carb cleaner and make sure it moves freely in and out (( some force is need to move it but not to much )) this sets the Idle and is it's not working you'll have all sorts of problems And most of time a good cleaning is all it takes ...
Old 01-06-2005, 08:52 PM
dfpasto dfpasto is offline
My '89 Royale stalled on a highway two weeks ago as I was @ 50 mph. Had it towed to my mechancic and he replaced the crank sensor. It's been fine since.
Old 01-07-2005, 06:43 PM
Hansnet's Avatar
Hansnet Hansnet is offline
That is a very very common problem with all the 3.8's from 86 to 95 or so. even later there were a lot of problems with those Crank sensors.
It could be a variety of issues, just get it scanned.
97 eighty eight stalling bennuss Eighty Eight 10 08-25-2005 11:19 PM
97 eighty eight stalling bennuss Eighty Eight 3 08-16-2005 05:37 PM
91 eighty-eight stalls going around turns tja0 Eighty Eight 2 01-10-2005 09:33 AM
Stalling 1991 Eighty-Eight hmwaters Eighty Eight 2 07-27-2004 01:30 PM
89 Oldsmobile Eighty Eight Royal Stalling HGBBRAC03 Eighty Eight 4 12-16-2003 08:49 PM
