Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 08-18-2005, 09:31 AM
bennuss bennuss is offline
97 eighty eight stalling
My car randomly stalls. Sometimes it only sputters and the gas pedal doesn't work to increase the speed. If let it sit, it starts up fine or with sputtering but then it passes and drives fine. I gave my car in to a mechanic and he insisted it was the fuel pump. He said he tested it and gave it power and it was weak.It also generated a code o2 sensor and misfire.He claimed the fuel pump could do that. Well $600 later new fuel pump and filter and new air filter as I pulled out of the mechanic it stalled. I let it sit and after a couple of restarts it caught but it was still sputtering like all the cylinders weren't working. It wouldn't go over 5 mph when revving then the sputtering stopped and it started driving normally. It also generated a code random cylinder misfire. While it was stalled or sputtering he did a fuel pressure test with the new fuel pump and it wouldn't go over 20 and the needle was jumping all over. He changed the fuel pump again on the chance the first one was faulty. Also changed the fuel pump relay and the Fuel Pressure Regulator. Still broken. I noticed that when it happens either the power windows don't work (I only know the drivers buttons) or they do and by opening the window or shutting the window before the stall happens while the engine is going crazy it starts to drive normally.It seems to be electric but where should I start. I''m going crazy.
Old 08-18-2005, 09:35 AM
hazzzmattt hazzzmattt is offline
Re: 97 eighty eight stalling
i know this sounds simple but you need to check the alternator. it could cause everything youre saying. no other single componant on that thing could cause all of those faults at one time except the alternator.
Old 08-18-2005, 10:48 AM
The alternator is only about 6 months old
Old 08-18-2005, 07:47 PM
Re: Re: 97 eighty eight stalling
When the car is acting up the windows don't work even off of the battery. Also the radio usually shuts when the doors are opened but when it is acting up it doesn't. The latest is the starter doesn't crank
but the lights work fine so it seems the battery is charged.
Old 08-18-2005, 08:11 PM
its an alternator and probably a reman one at that. ive seen plenty of um bad out of the box. it only takes a minute to see if this thing is charging when it starts acting up. its possible that its even over charging from what youve explained.
Old 08-18-2005, 08:56 PM
Why wouldn't the windows work off of the battery even though it is charged and the lights work fully. How should I go about checking it. It is stuck in my office parking lot and I can't get it to a mechanic.
Old 08-19-2005, 01:13 PM
joe4speed joe4speed is offline
Send a message via ICQ to joe4speed Send a message via AIM to joe4speed
If you have a basic set of tools, you can take the alternator off and bring it to a local auto parts store. They usually have alternator testers and test them for free.
Joe!
1988 Mustang GT
1993 Olds 88 LSS
http://www.joe4speed.com
Co-owner: RiceHatersClub
Old 08-19-2005, 02:39 PM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
Loosen the tensioner pully (18 or 19 mm) w/ at least a 1/2 inch socket wrench and remove the belt first.
Alternator mount bolts: 13mm
Upper Elec. Connector: Unplugs
Lower Elec. Connector: 6, 7, 8 mm (don't remember exactly.
Pretty simple stuff.
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 08-21-2005, 09:18 PM
It was a bad ground. There is a bundle of wires under the drivers side door jam. The ground for the fuel pump and the windows and powerlock is spliced together and it was loose.
Old 08-21-2005, 09:30 PM
Hansnet's Avatar
Hansnet Hansnet is offline
**very common actually on these years.
Old 08-25-2005, 11:19 PM
shadowhawk shadowhawk is offline
Send a message via AIM to shadowhawk Send a message via MSN to shadowhawk Send a message via Yahoo to shadowhawk
Lightbulb Re: 97 eighty eight stalling
I know what you are going through and feeling mine is doing the same exact thing I have a friend that used to be a mechanic he told me that these types of cars do that between 105,000 and 130,000 miles, and said that it is something to do with the intake but he cant remember what exactly. hope this helps you some
