Old 06-04-2003, 07:37 AM
DelSolSI-96 DelSolSI-96 is offline
Send a message via AIM to DelSolSI-96
Alpine Ground wire?
I just bout a new alpine cda-9811 and on the wire harness it has its own ground would it still work if i used the ground on the wire harness or should i just ground it to the chassis. I don't think it would make a difference but any thoughts.
Got Sol?
Old 06-04-2003, 09:35 AM
sickhonda's Avatar
sickhonda sickhonda is offline
It will work with your wire harness.
You just need to give it a separate CONSTANT power connection directly from the battery due to the high power output of the HU.
REM wire touched my ground wire.. how can i fix the issue? alexdeer18 SC/SL/SW 3 07-14-2011 02:41 AM
How to ground wires CaboWabo Engineering/ Technical 9 07-17-2003 12:19 PM
R-1 Sports Grounding Wires jrgcivic '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 5 01-05-2003 05:29 PM
Ground Wires jrgcivic Car Audio 7 11-27-2002 03:46 PM
Help with a loose ground wire ned946 Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 9 12-05-2001 06:11 PM
