Old 05-23-2012, 01:14 PM
MikeS1969 MikeS1969 is offline
Problems with Tire Pressure Sensors
We bought our Caravan in 2010 and it has roughly 26000 miles. In that span we have had to buy three sets of tires because of the faulty tire sensors.
Basically, the tire pressure sensors rusted/corroded until they failed. One tire went flat last year. One blew out while we were driving. When we examined the other two, one was essentially sitting in place and could have failed at any moment. The last was corroded enough to require replacement.
And don't even get me started about the Dodge Customer Service and dealer response. The service manager at our dealer assured me that he's only seen this in 2-3% of their vehicles. Yet all four of our sensors were bad.
Has anyone else experienced this?
Old 06-21-2012, 06:55 PM
b1lk1 b1lk1 is offline
Re: Problems with Tire Pressure Sensors
So because you have these sensors you feel you no longer need to visually inspect and check tire pressures? I'd be pissed that the system is weak as well, but you still need to rely on your eyes and a physical gauge. I have seen a pretty high failure rate for the type of sensor they use, they corrode badly.
Old 06-22-2012, 10:17 AM
danielsatur danielsatur is offline
If one was not to trigger the alarm system, it could be a big problem.
Are you taking your van to the same service shop?
Does the Air compressor have a water separator on it?
Old 06-22-2012, 01:28 PM
This is the inherent problem with TPS systems. People will trust them far too much.
Old 06-22-2012, 01:45 PM
With a condom type valve stem cover and a rubber tire wrapped around it, there shouldn't be any moisture or water.
The nitro filled tires might be better for the tire sensors, than blowing compress air/water into the tire.
TPMS sensors, valve stem, tire
Considering buying a 2000 Malibu with a few problems, is it worth it? AlxBlack17 Malibu 1 07-05-2011 12:28 PM
Tire Pressure Sensors Aurora01 Aurora 5 04-15-2005 11:07 PM
Where are the tire pressure sensors??? 94sportsedan Grand Prix 9 12-26-2004 08:13 PM
Problem with tire pressure warning light JTrujillo86 Alero 9 12-11-2004 02:58 PM
Low Tire Pressure sensor blackalero Alero 6 09-07-2004 09:06 AM
